FPV flying my 3DR quad in Discovery Park in Seattle. I was able to get behind trees and still get a crisp video signal to the goggles.
Gear:
NAZA w/GPS
5.8ghz Video tx/rx
GoPro 3 Silver
5000mah 3S battery
Fatshark SD Base Goggles
Using Quadframe US landing gear with vibration dampeners
You can see the rubber oring in this picture between the camera mount and the mounting plate on the legs.
You have your go pro in the same place as mine, and attached to the same legs - did you get any vibes in your video first time out, and what did you do to fix it? I see you went with the rubber dampeners attaching it to the frame.
