This is just a quickie before I go to bed.
Those with a Futaba 6EX will know the toggle don't always feel right when you are flying a plane well as I use both my extra channels for mode switching I figured enough was enough and put them together. I took off the back and traced the wires back to a PCB point. Unsoldered, swapped over and resoldered them, 5 minutes and done.
Some quick measuring and my Tesco A4 label sheets were put into action on the top so everything is labelled properly still. The picture below shows the two points which connect to the switch marked above.
Disclaimer: Neither I or DIYdrones take NO responsibility for any damage you cause to your equipment try to do this or something like it to your own equipment. You break it, its your fault.
Tags: futaba, mode, switch, toggle
Comment by John Campen on October 5, 2012 at 12:18am
what does that do though? Does it give you 4 flight modes? if so how do you set the program up in the TX?
Comment
