ghetto fpv quadcopter: idea 2
3689545363?profile=original
Ok, so in my previous blog post: http://diydrones.com/profiles/blogs/ghetto-fpv-quadcopter-1 I wrote a fairly comprehensive instruction on how to build a ghetto fpv quadcopter for around £115. It works well. However, just this week I was given a camera module MC495a
I decided to test it and see how it works.
Connecting the mc495a to our 200mw tx is fairly straight forward. Desolder the simple usb wire from the tx's video out, snip off the connector attached to the rca a/v adapter cable included with the camera, and solder that on to each of the 4 connections on the tx - video, audio, power, ground. Not forgetting the diode at the power. Done. Now, you just plug the camera into that new 4-pin connector. I sealed the exposed back of the camera using tape.
3689545384?profile=original
mounting the camera and tx I tried a different approach than the top-mounted 808 #16 camera, as I have thought about the damage to the cloverleaf antenna I have had to repair often, using this method. I opted for a tail-like antenna mounted out the rear of the quadcopter using a simple 'bag-pouch' made from anti-static plastic bag material and a small ziptie. The front, I screw mounted the camera to the front of the quad frame (the screw was a silver screw from the case of the 808 #16 camera).
Simples...
Using an rca-to-3.5mm plug pigtail cable, connected to the rca audio plugs on the rc305 output, I am able to get audio aswell as video on my controller, using a cheap speaker: like this.
I like the camera, as it is lighter and seems more robust than an uncased 808 #16 camera. It seems like the picture quality, and response time is better too.
Downside is that it isn't recording 720p vdeo to sd card. However they can be swopped over if needed, or I may try a WLtoys v262 in the future, of something that can lift both fpv setup & 808 #16 cam (possibly with a cheap gimbal rig...watch this space)
I am recording this fpv camera using a cheap easycap dongle on a laptop, using virtualdub software. Works for me.
One problem I am having, is that I have learned to fly fpv by aiming to have on my monitor screen, half sky, half ground. And as such, as the sky is often naturally brighter than the ground, the camera adjusts for light, and makes the ground dark, shadowy, almost un-viewable. As the camera doesn't seem to have any way to adjust light exposure control, I am wondering what your solutions are?
I am thinking:
-Learn to fly with the camera pointing 90-100% ground, when level flying. (Could be risky monitoring level flight)
-stick some kind of graduated filter over the lens, so that the sky is dimmed, causing the ground to be lightened. I'm aware of photography-related graduated filters, but not tiny lens graduated filters. Anyone have experience with this idea?
How do you adjust/mount your fpv camera to get the best light exposure setting?????
http://dalybulge.blogspot.co.uk/
  • Team Ghetto Sheep! Nice work my friend. I am debating the v262, but I have mixed opinions so far. I hope to do some work on a little Team Ghetto Sheep project I have been cooking up, this weekend. Very hush hush...haha!
  • Well the light exposure setting is mainly a function of your camera. You can add some lightshield (plastic etc) on the top of the lens to prevent sunlight making your cam going crazy. I once had the problem with a chepo sony ccd (came with a cheap groundrecorder pack). Copter above the trees: White screen for seconds until cam adjusted, than below the trees seconds of darkness.... it was usable after all once you counted in the blindness effect. But problem solved with more expensive sony ccd .....
