3689627287?profile=original
Hi again,
Hereby I'd like to continue my project. As I said earlier, all parts were printed using a Stratasys 3D printer, which uses FDM technology and support material too. These were the parts coming from the printer:
3689627371?profile=original3689627402?profile=original
3689627387?profile=original
3689627320?profile=original
I made a small PCB for the modified USB plug:
DSC_0818_www.kepfeltoltes.hu_.jpg?width=200DSC_0819_www.kepfeltoltes.hu_.jpg?width=150DSC_0820_www.kepfeltoltes.hu_.jpg?width=145
DSC_0821_www.kepfeltoltes.hu_.jpg?width=150 DSC_0824_www.kepfeltoltes.hu_.jpg?width=150 DSC_0825_www.kepfeltoltes.hu_.jpg?width=170
Assembly of the arms:
DSC_0841_www.kepfeltoltes.hu_.jpg?width=300
DSC_0839_www.kepfeltoltes.hu_.jpg?width=300
DSC_0845_www.kepfeltoltes.hu_.jpg?width=300
DSC_0842_www.kepfeltoltes.hu_.jpg?width=300
USB plug assembled - plug-n-play solution for Mobius!
DSC_0852_www.kepfeltoltes.hu_.jpg?width=300
And finally some fully assembled shots. Now I'm waiting for the yaw motor and the controller to be delivered. After that I'll start testing in PART3. So stay tuned!!!
Best regards
Adrian
DSC_0850_www.kepfeltoltes.hu_.jpg?width=300
DSC_0851_www.kepfeltoltes.hu_.jpg?width=300
    Fantastic job!!!
  • That's the spirit, Adrian! Rest assured that I will make a contribution if I print out your design.
  • Hi guys, finally I decided to share STL files. So please check out PART2.5!!!
    If you like my work, donation link is in the post too. Cheers!
  • Would you be willing to share your STL file for the design?  I'm really interested in working with what you have for another done project I plan to build. Your file would be a big help in get a jump on development for my project.
    Happy New Year!
  • Hi, right now I'm nbuilding my X-UAV Talon. The gimbal will be in the nose.
    As soon as my plane is ready, I can do the initial testing in the air.
    I'll post my results in the PART3.
  • Adrian, what is the latest on your gimbal? I am looking at doing the same thing with a bigger zoom camera and would be interested to know how you found the "stiffness" of your in the air.
  • Yes, that's the question what ariflow will do at that speed.
    @Adrián Nagy Hinst , Oh, I see.  Yes, you did mention the hollow-shaft motor, I guess I didn't understand the significance in relation to the wire routing.
    It would seem to me that the sphere's center-point will move out of alignment when panning; so it would likely not be mounted behind an opening in the fuselage, but hung out in the slipstream (?)
    At 100 kph, this swinging motion and air pressure would effect the handling quite a bit, wouldn't it?
  • T3
    Looks nice!  You should wrap those external cables in a sleeve, something like this.
  • MR60
    Hello,
    Can you share the STL files for the parts?
    Looks very good.
