This is the way I mount my GPS and CoPilot sensor units onto my high wing Kadet Senior.It is a simple turret made of balsa scraps in which the GPS (Locosys LS20031) lies on top and the CoPilot lies below.The GPS board is plugged into the turret with a 4 pin header since it needs independent Vcc (3.3volt unit).A four wire cable (scavenged from an old PC) with female header plug was added to the CoPilot to get rid of the built in connector. The CoPilot sensor is plugged on the side of the turret.Finally, four magnets will be epoxied at the base of the turret and 2 x 4 pins female headers will be epoxied through the top surface of each wing half. So the turret can be snapped/plugged steadily onto the wing and taken off after flight to be carried with other valuable devices in a separate case.Here some pics of the modifications FMA CoPilot thermopile sensor
Soldering breakout cable to dismantled FMA CoPilot
CoPilot with breakout cable
Locosys LS20031 GPS board with 4 pin male header
Plugging GPS board into turret
Adding some foam pad between GPS and CoPilot
Plugging CoPilot and inserting into turret
Turret back view with inserted devices
Turret side view
Some pictures:
My GPS-XYsensor removable turret
Closer view
With turret off
Erwin
When I need to reprogram the Locosys, I use an FTDI breackout board powered at 3.3V. It's the only situation where the GPS Rx pinm is used in my setup.
just recognized that's only a voltage converter, how do you convert the 5V Tx line to 3.3V for the Locosys ? Or have you added simply a resistor ?
Erwin
Erwin
I use a 5v/3.3v DC/DC converter I ordered from Ebay (5 pieces pack) and I am glad with them.
There's a post about these here. The specification sheet is here.
By the way, what 3.3 V level converter have you used for the Locosys ?
Erwin
In fact, I intend to use the sensor on my UAV for ArduPilot code ver. 2, and once in a while the whole FMA CoPilot on my son's trainer. Struggling with this fixed length flat cable and with these - in my opinion - unadapted connectors is not appealing to me.
Just a note on the sensor board: it is, and everything soldered on it too, covered with some sort of transparent hard glue. This is probably intended for bad weather flying, although the thermopile windows would hardly be usable in wet weather! I tried first to scratch the connector solder joints to get rid of the glue but that wasn't the way. I then simply melted the glue covering the solder joints with the tip of my iron. Once your breakout cable is soldered, do not hesitate to check out each connection with your multimeter!
