Better trust then the 100 Amp ESC withe the Dlux
Test setup 2200mAh 3C 20C Lipoly DT850 motor 11 X 4.7 Pusher Prop
Rpm/V: 850kv
Max Watts: 380W
Max Amps: 35A
Max Volt: 7.4~14.8v (2~4S)
Idle Current: 1.5A
Resistance: 0.039 ohms
Weight: 107.1g
Shaft: 4mm x 39mm threaded
Can Size: 41mm
Mount Diameter: 30mm
Spec.
Max Cont. Current: 30A
Max Burst Current: 40A
Max BEC Current: 2A
BEC Voltage: 5.5v
LiPo: 2~4S
Weight: 23grams
Max RPM (2-pole): 200,000rpm
Size: 51 x 27 x 11mm
Motor Plug: Female 3.5mm bullet Connector
Specification:
Working voltage range: 0-60V
Working current range: 0-100A
Power: 0-6000W
Cell count: 1-6S
Battery type: LiPo/LiFe/LiIon
Weight: 140g
Dimensions: 103x49.5x20mm
Working temperature range: -20~50°C
