http://www.youtube.com/watch?v=cipTQAUM-v4
Note** these are 100meter orbits with really strong winds to provide a setting for this test. Hence the reason why the autopilot has a hard time holding a perfect circle. However the improved algorithm is holding so much better in the high wind scenario than the original algorithm!
This is an example of how to eliminate the oscillation in ground track using a heading error>bank angle type proportional controller. The groundspeed of the vehicle determines its turn rate for a given bank angle. Typically you tune the PID (only P is needed) for a given trim airspeed and assume that the ground speed is fairly constant and something close to the airspeed. However when there is high winds, this isn't the case. The ground speed can change +-50% in some cases in and out of phase with the wind if not more.
This causes oscillations on the "upwind" side because the turn rate is so much higher. To take this nonlinearity out of the system, I added the turn rate equation into the mix and solved this problem. The largest contributor to this problem is the GPS lag. So using this turn rate equation in the middle, it makes the controller more predictable with the changing ground speed.
I made an attempt at a video so hopefully it will better explain what is going on here. Especially beings a lot of people are having this problem!
-Beall
Comment by Paul Bizard on April 2, 2010 at 1:07pm
Comment
203 members
1355 members
207 members
58 members
Powered by
