Here's how to use Blimpduino:
First thing, needless to say: inflate the envelope. For that you'll need helium. You can get it in a party balloon kit that you can find at most Targets or Wal-Marts or any party supply store. You can also buy it from Amazon, or rent a tank from a local welding supply store.
You shouldn't need to fill the whole envelope with helium. Just tape the BlimpDuino board (with battery and RC receiver) temporarily to the envelope and add helium until it floats upwards pretty strongly with that weight. The envelope will still look pretty saggy, so get a straw and fill the rest with air so it looks full. You can then ballast the blimp by taping on coins until it's neutrally bouyant. The envelope will slowly leak over a week or two, so if you have a little extra buoyancy, you can just take off ballast from day to day as it loses a little lift.
Note that the envelope in the kit comes with some foam cutouts, which can be taped on to the envelope as fins. They looks cool and can add directional stability, but are not necessary. I usually don't bother with them.
Make sure the board is configured as per the photo above, with the switch side facing forward and the props pushing the air backwards, which you can check in RC mode. (click on the photo for a bigger version). Tape or velcro the board to the bottom of your blimp, with all the components facing down.
Note: The Blimpduino code sends lots of useful status and debug information that you can see if you leave your FTDI cable plugged in and open the serial window in the Arduino IDE (circled in red below):
If that all works, it's time to try...
When the blimp can "see" the beacon, it's will go into navigation mode and the vectoring servo will move proportionally as the blimp steers towards the beacon (if you're holding the beacon and walking around, it should follow you). If the the blimp can't see the beacon, it goes into altitude hold-only mode, where the vectoring servo is pointed all the way up or down and it just holds altitude in one place.
Enjoy the show!
Comment by Mitch Patenaude on June 30, 2009 at 10:38pm
Comment by Brent Waguespack on October 20, 2009 at 5:48am
Comment by Chin Wah John Tan on October 29, 2009 at 7:57am
Comment by Chin Wah John Tan on October 30, 2009 at 7:08pm
Comment by Ricardo Colas on November 4, 2009 at 3:19pm
Comment by Ricardo Colas on November 4, 2009 at 3:55pm Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.32 members
18 members
32 members
109 members
22 members
© 2012 Created by Chris Anderson.
