The only pieces left to complete are numSV doesn't seem to be set right with the Ublox GPS adapter so I can't report on the number of satellites and I need to figure out a UTC clock source for the UTC time and DATE field. Might have to enable those messages on the Ublox.
I've only done bench testing with this as I'm still building my UAV, so if anyone wants to help out please add this to your print.pde file:
void print_remzibi(void)
int nMult=0;
int nMeters=0; //Change this to 1 for meters, 0 for feet
long current_lat;
long current_lng;
float lat=0;
float lng=0;
int lat_dd=0;
float lat_ff=0;
int lng_dd=0;
float lng_ff=0;
char *lat_hemi;
char *lng_hemi;
char *lat_zero;
char *lng_zero;
if (nMeters==1)
nMult=1;
else
nMult=3.2808399;
digitalWrite(13,HIGH);
Serial.print("$GPGGA,");
Serial.print("064951.000");//UTC time
Serial.print(",");
if(current_loc.lat < 0)
current_lat = current_loc.lat * -1;
lat_hemi = "S";
lat_zero = "0";
else
current_lat = current_loc.lat;
lat_hemi = "N";
lat_zero = "";
lat_dd = (int) (current_lat/10000000);
lat_ff = (float)((current_lat - (lat_dd * 10000000)));
lat_ff = 60 * lat_ff;
lat_ff = (float)(lat_ff / 10000000);
lat = (float)(lat_dd * 100) + lat_ff;
Serial.print(lat_zero);
Serial.print(lat);
Serial.print(",");
Serial.print(lat_hemi);
Serial.print(",");
if(current_loc.lng < 0)
current_lng = current_loc.lng * -1;
lng_hemi = "W";
lng_zero = "0";
else
current_lng = current_loc.lng;
lng_hemi = "E";
lng_zero = "";
lng_dd = (int) (current_lng/10000000);
lng_ff = (float)((current_lng - (lng_dd * 10000000)));
lng_ff = 60 * lng_ff;
lng_ff = (float)(lng_ff / 10000000);
lng = (float)(lng_dd * 100) + lat_ff;
Serial.print(lng_zero);
Serial.print(lng);
Serial.print(",");
Serial.print(lng_hemi);
Serial.print(",");
Serial.print("1,");
Serial.print((int)numSV);//number of sats
Serial.print(",,");
Serial.print(current_loc.alt/1000);
Serial.println(",,");
delay(50);
Serial.print("$GPRMC,");
Serial.print("064951.000");//time
Serial.print(",,,,,,");
Serial.print(ground_speed/100,DEC);//ground_speed
Serial.print(",");
Serial.print(ground_course/100,DEC);//ground_course
Serial.print(",");
Serial.print("020410");//date
delay(50);
//$M message bus system for remzibi OSD
Serial.print("$M");
Serial.print("82"); // Hex Column (01h - 1Eh) for small fonts add 80h (81h - 9Eh)
Serial.print("09"); // Hex Row (01h - 0Dh for NTSC, 01h - 10h for PAL)
Serial.print("BA"); // Hex address of First Character
Serial.print("00"); // Hex address of Last Character
switch (control_mode){
case MANUAL:
Serial.print("MANUAL");
Serial.println(" ");
break;
case STABILIZE:
Serial.print("STABILIZE");
break;
case FLY_BY_WIRE:
Serial.print("FLY BY WIRE");
break;
case AUTO:
if (wp_index == 0)
Serial.print("HOME:"); //Min length = 7
Serial.print((int)(wp_distance*nMult));
else
Serial.print("WP"); //Min length = 6
Serial.print((int)wp_index);
Serial.print(":");
break;
case RTL:
Serial.print("RTL");
break;
case LOITER:
Serial.print("LOITER");
break;
digitalWrite(13,LOW);
Then in your main Ardupilot_25_04 file add the following below the if print_telemtry section:
if(REMZIBI)
print_remzibi();
Also you'll want to then set REMZIBI to 1 in your define.pde
Could you take a look at the execution time of print_remzibi(). Possibly there is a need to break it into pieces so that their execution can be staggered over several main loop iterations so we don't bog the main loop down.
if(gps_time_hour < 5)
gps_time_day = gps_time_day - 1;
int difference = 5 - gps_time_hour;
gps_time_hour = 24 - difference;
else
gps_time_hour = gps_time_hour - 5;
case 0x21: // ID NAV-TIMEUTC
gps_time_month = join_1_bytes(&UBX_buffer[14]);
gps_time_day = join_1_bytes(&UBX_buffer[15]);
gps_time_year = join_2_bytes(&UBX_buffer[12]);
gps_time_hour = join_1_bytes(&UBX_buffer[16]);
gps_time_minute = join_1_bytes(&UBX_buffer[17]);
gps_time_second = join_1_bytes(&UBX_buffer[18]);
//timezone stuff to make it local time
//CDT is -5 from UTC
//CST is -6 from UTC
break;
Next add the following as well to the GPS_UBLOX:
// Join 2 bytes into a long
int32_t join_2_bytes(byte Buffer[])
longUnion.byte[0] = *Buffer;
longUnion.byte[1] = *(Buffer+1);
return(longUnion.dword);
// Join 1 byte into an int
int32_t join_1_bytes(byte Buffer[])
intUnion.byte[0] = *Buffer;
return(intUnion.word);
Here is the new print_remzibi:
int nMult=0;
long current_lat;
long current_lng;
float lat=0;
float lng=0;
int lat_dd=0;
float lat_ff=0;
int lng_dd=0;
float lng_ff=0;
char *lat_hemi;
char *lng_hemi;
char *lat_zero;
char *lng_zero;
if (nMeters==1)
nMult=1;
else
nMult=3.2808399;
//$GPGGA,,,,,,,,,,,,,,
if(gps_time_hour < 10)
Serial.print("0");
Serial.print(gps_time_hour);
if(gps_time_minute < 10)
Serial.print("0");
Serial.print(gps_time_minute);
if(gps_time_second < 10)
Serial.print("0");
Serial.print(gps_time_second);
Serial.print(".000");
Serial.print(",");
lat_hemi = "S";
lat_zero = "0";
else
lat_hemi = "N";
lat_zero = "";
Serial.print(lat);
Serial.print(",");
Serial.print(",");
lng_hemi = "W";
lng_zero = "0";
else
lng_hemi = "E";
lng_zero = "";
Serial.print(lng);
Serial.print(",");
Serial.print(",");
Serial.print("1,");
Serial.print(numSV,BYTE);//number of sats
Serial.print(",,");
delay(50);
//$GPRMC,,,,,,,,,
Serial.print("0");
Serial.print("0");
Serial.print("0");
Serial.print(",");
Serial.print(",");
if(gps_time_day < 10)
Serial.print("0");
Serial.print(gps_time_day);
if(gps_time_month < 10)
Serial.print("0");
Serial.print(gps_time_month);
Serial.print(gps_time_year - 2000);
// Serial.print("020410");//date
delay(50);
Serial.print("$M");
case MANUAL:
break;
case STABILIZE:
break;
case FLY_BY_WIRE:
break;
case AUTO:
if (wp_index == 0)
else
Serial.print(":");
break;
case RTL:
break;
case LOITER:
break;
Finally, enable TIMEUTC on your uBlox module. I still can't seem to get numSV to display anything with SOL enabled.
The uBox needs to output NAV-SOL instead of NAV-STATUS to get the number of satellites. uBlox are shippong from Jordi now with Nav-SOL enabled over Nav-STATUS. You can change that with uCenter, I think.
Nice work.
Jason
BTW, the Remzibi OSD are back in stock in the DIY Drones store.
