3689448435?profile=original
Some who have followed my blog posts will know that I have been working on my HDwing design series for a return-to-launch glider concept using ArduPilot Mega.  Everything I have revealed so far has been based on relatively conventional flying wing ideas. Till now...
This forward-swept flying wing concept was inspired by the work of Justin Ammon (EdgeRC / birdofprey) that I spotted on www.rcgroups.com  A period of spreadsheet analysis and messing about with various X-plane simulations over te Christmas/New Year break demonstrated to me that, whilst unlikely to be a walk in the park, a forward swept wing could be made to work and would yield some worthwhile advantages over a mainstream flying wing.
A bunch of CAD work and several iterations later, based on an acceptably flying X-plane model, I came up with this design and I am now committed to bringing it to reality.
3689448508?profile=original
3689448525?profile=original
3689448555?profile=original
One of the difficulties with the forward swept design, especially as a pusher, has been to establish a workable centre of gravity position.  This necessitates the use of a protruding fuselage (a deviation from the pure flying wing) but offers an advantage of placing a payload area virtually right on top of the CoG.  Thus the design can accept a wide variation in payload mass and still be (X-plane) flyable.  How this translates into real world usefulness is yet to be seen, but it bodes well.
The drag-based yaw stablity of a conventionally swept wing also no longer works with a forward swept design, so the addition of a vertical stabiliser fin is required.  Bad for stealth, I know!
3689448368?profile=original
The nose cone has been sliced off at an angle to yield a removable camera pod as well as a large access aperture for working on the interior of the airframe.  I am designing in a removeable avionics tray so that the majority of the avionics and payload can be mounted on a lightweight demountable chassis to aid bench testing, modification and repair.
3689448542?profile=original
The location of the battery at just ahead of the CoG will allow me to increase its capacity with minimal adjustment to balance.   It is also is attached to the avionics tray for ease of complete systems-level bench-testing.
Personally, one of the attractions of the forward swept wing is that, similar to a canard design, all of the wing surface is lifting to produce pitch stability.  The lift distribution isn't the most theoretically efficient, but at higher speeds and lower C_L, this is not such a huge penalty.  The X-plane simulation shows a best L/D of about 19:1, which is not so bad for such a stumpy, low aspect ratio craft.  My earlier HDwing designs didn't get this far and they had the advantage of winglets and a lift distribution closer to the theoretical optimum.
The forward swept wing layout does come with some compromises but also offers compensatory advantages to exploit.  There is a whole host of detail design work to be done, but hopefully a worthwhile UAV airframe will result.  Time will tell.
  • It's my own design folding prop based on a HK CF blade for want of anything better.  I made up a couple of samples but it needs some further work.
    More info here, Kevin
    Free CAD Designs, Files & 3D Models | The GrabCAD Community Library
    The GrabCAD Library offers millions of free CAD designs, CAD files, and 3D models. Join the GrabCAD Community today to gain access and download!
  • PeeBee,
    It's a stalled project, pretty much.  The aerofoil section I originally chose was never going to function and it forced me to do a bunch of research and learning.  The fuselage plug that I made also sits here on my desk as a reminder not to jump too soon!  I have a reworked CAD model with revised aerofoil sections that would do a decent job and the concept still offers some advantages, but I have put my limited resources elsewhere for now, not that there's much to show for it yet.
  • Hi Mike. There is an earlier blog post where the issues of thermal management were discussed. It turns out to be less complicated in practice than first imagined
  • I wanted to add back into the blog two posts that were made when this blog was accidentally published too early.  The first was:
    bGatti - You might change the diagonal to avoid landing on two parts. If the "cockpit" piece sloped \ instead of /, this smaller and more easily replaceable piece would likely absorb the balance of bad landings.
    and the second was:
    MC - Andrew, It is very nice visually appealing design, very good animation and fantastic music selection! Is it legal to use (quad band) GSM on high altitude? I think there are some rules and regulations where  (how high) can we use GSM.  What about the rules/regulation about the size/weight, on-board avionics selection for the HAB operations?  Is it legal (how to make it legal) in Australia to launch HAB with such a payload?
    @bGatti, I guess a bad, nose-first landing will take out the nose-cone, but a good (auto?) landing will actually only land on the main fuselage, at least on level ground.  I take your point though and will consider the strength of the nose-cone intersection under a 'sub-optimal' arrival!
    @MC, you raise two very interesting and important questions. Firstly, I know that the FCC have a ban on mobile/cellular communications use whilst airborne, but I don't know of anything similar in Australia.  I have done some searching for regulations about this but I wouldn't claim to have any definitive answer in this area.
    Regarding the operation of the whole rig in Australian airspace, the regulations that apply are in CASR101 under free balloons and, presumably model aircraft - it will always be an amateur/hobby project, at least as a HAB payload.
    The free balloon regulations are pretty easy to navigate and people have already sent HAB's aloft with payloads of similar and larger masses, presumably without getting into trouble.  As far as the model aircraft aspect is concerned, there are a few greyer areas and I read that OCTA, as long as I have line-of-sight, I can (claim) all is OK.  One thing I must check is whether class G, or anything considered OCTA goes beyond FL100 - I should know this, being a (lapsed) PPL, but...  Ultimately, I may choose to fly in an ambiguous geographical area and leave it up to the authorities to prove any flights actually occured in their jurisdiction...
    In any case, if and when the flight actually occurs, I will be doing my damnedest to ensure no conflict with manned aircraft.
  • Thanks Max!  I doubt you could do solar power successfully without an odd looking aircraft - well, more odd than this one!  The Helios is probably the best example of what actually works.
    Also, on the forward swept wing, most of the wing area is behind the CoG, so adding solar cells is putting mass in the most sensitive area.  Getting the CoG forward far enough has been something of a challenge without adding to it.
    Actually, as my brother pointed out to me over the weekend, the Helios holds one of the records for sustained straight-and-level flight at 96,863 feet!  Proof that you can still fly when you get up there! :)
    @Andrew
    Sure. Build it, flew it, engoy it. :))))
  • Thanks for your concern Vladimir, but I'm not prepared to just accept the advice of someone who says "trust me, I know best" but can't take the time to expound the reasoning behind his position. Engineering is science, not religion.
    Dear Andrew...
    I have > 20 years practical experience with build & flew RC models...Believe me, you gonna wrong way...
  • Thanks Dez!  Wow, I didn't know submersible flying existed till I googled about the Challenger, but it sounds a very cool idea.  Thanks for the info!
    @Jonathan - one more thing I forgot to add regarding the motor/propellor.  I found that it adds a useful degree of pitch (and possibly yaw) stability due to gyroscopic rigidity.
  • @Jonathan, I first considered a pure glider, but I added a motor for several reasons.  Firstly, it allows easier testing of the prorotypes.  Secondly, I can use it for landing positioning and potentially a non-landing recovery method I'd like to try.  Thirdly, it makes the craft more multi-role, which may be useful in the future.  I can make a pure glider derivative if I need to.
    @Vladimir, I respect your skepticism - it can be the sign of a good engineer!  It is a little more than a drawing though.  I have done a fairly extensive series of hand calculations and experimental simulations using X-plane.  I take your point that tractor is easier, but it doesn't permit forward-looking cameras, which is one of my requirements.
    The 'positive V' comment I take to mean dihedral.  In my X-plane experiments, I played with dihedral from positive through to negarive (anhedral) and discovered that anhedral improved stability markedly.
    I agree I can always use more tail volume too, but both the pusher configuration and balance requirements limit how much tail area and how far back I can push it.  I look at your Mamadu airframe and estimate where your CoG is and I think your tail volume wouldn't be too much greater than mine as it stands.  I'd be happy to do the calculations to compare them?  I guess it's really the ratio of tail volume to yaw inertia that is important too.
    @cvancollenstee - I need to get it flying successfully, but if it works well, I will consider commercialising it.
