here's some footage which highlights the features found on the
'Maveric', which was on display at the recent SOFIC 2011 event,
which was held in Tampa, FL. SOFLIC stands for "SpecialOperation
Forces Industry Concerence.
The Maveric has a flexible monolithic wing made from carbon fibre and
rip-stop nylon, allowing the wing to be bent completely around the fuselage.
The whole aircraft can be stored inside and deployed in less than two minutes
from a 6-inch diameter tube that resembles a jumbo poster tube. Ripstop
nylon is only used on part of the wing behind the leading edge. The rest of
the aircraft’s body (including part of the wing) is made from carbon fibre.
Comment by kucinkbatu on May 28, 2011 at 1:41pm
One source says $45,000 ea. to US, British, and Canadian military.
On the Maveric site they claim to use adaptive washout to improve handling in high winds. Tech specs say "20 kts sustained, 30 kts gusting". How does adaptive washout make it stable 30kt winds? Anyone know how this works?
Comment by bGatti on May 28, 2011 at 10:16pm
Comment by ionut on May 28, 2011 at 10:27pm
Comment by MarcS on May 29, 2011 at 1:41am Doesn´t look like the wing itself contains any controls. More like they are using elevons plus rudder. Regarding the shortness of the whole plane and the shape of the wing it´s probably designed to perform partly like a flying wing with additional control surfaces... I can´t see any other way to get it to stable flight.
It´s an interesyting design but I´m questioning robustness for "deployment". When you see videos of what a Raven has to withstand for example.... Then this bird is much too sopisticated.
Comment by Not Sure on May 29, 2011 at 3:39am Comment
51 members
87 members
683 members
184 members
Powered by
