Here we go again.
Like mp3 encoders before LAME, RTK GPS based on inexpensive GPS receivers & software has long been a dream that no-one has been able to get working.
http://gpspp.sakura.ne.jp/rtklib/rtklib.htm
For years, a Japanese team has used a discontinued uBlox module that costs just as much as a commercial RTK GPS solution. Now the latest hobbyist movement is to use just the GPS front end & do all the baseband processing in software. Unfortunately, we have no idea what to do with baseband GPS data to convert it into RTK corrected information.
http://www.maxim-ic.com/datasheet/index.mvp/id/5241/t/do
For years, Maxim has had a GPS front end available for $11 but only now has anyone tried doing anything with it. http://unreasonablerocket.blogspot.com/2011/02/gps-progress.html
It doesn't look like he's going to have enough time to finish it.
There are some notes on using a laptop for baseband processing but no actual sourcecode.
http://www.maxim-ic.com/datasheet/index.mvp/id/5241/t/do#Applicatio...
The only remaining step is really getting data into the format RTKLIB needs. This is really a movement worth getting behind, since RTK GPS would eliminate the pressure sensors, sonar, pitot tubes, & guesswork VTOL flyers have become familiar with. Well, unless you're in the business of selling pressure sensors, sonar, & pitot tubes.
Comment by Simon Wood on February 23, 2011 at 2:03pm Having 'spoken' with Tomoji regarding the SDR GPS, this is intended for the 2.5.0 release. If you refer back to about October last year you will see that the SDR GPS will take a fair chunk of processing power.
RTK GPS is currently obtainable with the Ublox and SkyTraq receivers, and of course the much more expensive commercial/survey GPS.
Comment by Hamish on February 23, 2011 at 5:25pm i like not depending on GPS for when my foamie makes it to mars :P
Comment by bcr on February 23, 2011 at 10:04pm
Comment by wahaha686 on April 10, 2011 at 10:38pm
Comment by Jack Crossfire on April 10, 2011 at 11:05pm For converting the baseband data to navigation solutions, there's fastgps: http://sourceforge.net/projects/fastgps/
Converting the baseband data to a format fastgps expects & linking fastgps to rtklib are the obvious missing pieces, but probably lawsuit bait.
Getting enough CPU power into an aircraft to process it is still cost prohibitive. The most economical solution is to use a $40 uBlox 5 on the aircraft & just run fastgps + rtklib on the ground, to generate DGPS corrections. That should give highly accurate 4Hz navigation. The problem is getting RTCM messages out of rtklib, & then fighting the lawsuits.
An RTK GPS system for under $100 is the kind of disruption that drew lawsuits from Fraunhoffer, in the 1990's, over mp3 encoders. Nobody wants to put any missing pieces in the libraries that might awaken Novatel or uBlox.
Comment by wahaha686 on April 11, 2011 at 11:18am
Comment by Simon Wood on April 11, 2011 at 11:34am Remember that RTCM is just a compression scheme for the Psuedorange/Phase/other data, you could just as easily send uBlox binary protocol over a link (of sufficient bandwidth/reliability).
RTKLib does have a future feature of RTCM out... just needs to be coded ;-)
Comment by wahaha686 on April 11, 2011 at 12:35pm Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
