Following my previous unsuccessful attempts at building a quadcopter (I have serious issues with the balancing and stability) I've decided that it's likely all this is due to VIBRATIONS and it was time to get into the nitty-gritty of some measurements...
While they are obviously far from complete or scientific, they do show how complex the "vibrations problem" is...
You can find the graphs on my blog (http://trandi.wordpress.com) and do let me know if :
- you would like some more details / numbers
- you have any other suggestions about how to reduce them
thanks,
dan
Comment by dan on March 26, 2011 at 1:23am You are right, I have not balanced them.
Everybody "out there" says it's an important part of the vibration reduction effort, but it seems to me that the vast majority of people manage to fly quads without bothering...
So while it can only help, I don't have the necessary stand (and patience :) ) so for now I'm sill struggling to understand what the problem is in my case...
I'll try to post today the measured vibrations with an updated frame...
Comment by dan on March 26, 2011 at 10:07am Phil, thanks a lot for your comments and suggestions !
I'll definitely look into the "gyro tape", even though I've already tried simple 2millimeters thick foam tape, with no noticeable effect...
As for the Hyde Mount, wow... looks quite interesting, but hard to put together, especially 4 times ! lol :)
dan
Comment by Luis Mauro on March 26, 2011 at 4:34pm Hello Dan, I had a lot of experience with vibration I have some clues for you:
- APC propeller are the best, even with no balancing job, they have good balancing,
- Use the original propeller holes, don´t drill it for a larger hole,
- Use motors up to 1000rpm/Volt because the vibration increases with the square of the rpm,
- The stiffness of the quad structure must be tunned to "filter" the vibration like a "low-pass filter (it´s pretty difficult to explain in a few lines). The quad structure must attenuate the vibration that comes from the engines/propellers!
- CSM gyro tape can be used to attenuate even more the vibration,
- Finally, the code (software) that you´re using to read the accelerometers and gyros signals must have a high-pass filter feature
/edit by moderator: it needs to be a low-pass filter
@Luis
- So super stiff motor-motormount-frame bad idea? better to put some dampening between motor and frame to do lowpass? Could you give some hints for this?
- where can I find gyro tape?
- Does de APM code do high-pass filtering for sensors? gyros may need a high pass to avoid drift, but what about the accels? do they need high pass filtering too?
Comment by dan on March 27, 2011 at 5:29am That's a typical simple LP filter, some kind of weighted moving average.
Comment by Luis Mauro on March 27, 2011 at 8:29am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.249 members
183 members
693 members
24 members
51 members
Powered by
