Status of Project:
Hardware Available and in public roadmap.
3689394841?profile=originalI wrote this post for me , for try to understand where this huge project are  going and for all our  developer , user and people that daily ask me a lot of things about It. I hope that this is a simple guide about what we're doing .
Multipilot32 (LYIF)
http://www.virtualrobotix.com/page/multipilot32-1
http://www.virtualrobotix.com/forum/topics/multipilot32-getting-started
http://www.virtualrobotix.com/profiles/blogs/multipilot-32-power-point
Status of availability:
  • In stock 4 pcs.
  • Next batch production will be available in second week of april.
  • The product is available for developers, OEMs, students.
  • The Product is available for end users.
If you want Buy the product contact : http://www.virtualrobotix.com/profile/ElisaLonga?xg_source=activity
3689394793?profile=original
Supported devices:
  • DiyDrones Oilpan.
  • PPM SUM Serial RADIO receiver same as used by Mikrokopter.
  • Standard PWM ESC.
Upcoming device support:
  • Standard multichannel PPM rc radio rx (need library implementation, HW is ok).
  • DiyDrones GPS (need porting of library, HW and low level library is ok).
  • DiyDrones Magnetometer (HW is ok, need low level i2c library and porting of apm library).
  • LN IMU (work in progress).
  • LN Navigation Expansion Board GPS, BARO.
3689394700?profile=original
Hardware in public roadmap:
  • LN Multipilot32 IMU (work in Progress).
  • LN Navigation Expansion Board GPS, BARO (work in progress).
  • Next Revision of Multipilot32. RTF (work in progress).
  • Pico CPU JTAG POD.
Integrated Development Enviroment
There are available two kind of enviroment one for entry level user supported by a branch of Arduino v 018 ide , called VRIde . Another is a complete professional Eclipse enviroment that support make project, upload firmware and debug using jtag functionality.
Available Ide :
VRIde rev 0.0.1
  • simple user interface.
  • Editing Code.
  • Support C/C++ and wiring framework.
  • fast editing and compile standard example.
  • fast editing and compile standard library example.
  • serial terminal interface for debugging.
  • using external Demo Flash loader for update firmware to MP32.
Link: http://code.google.com/p/multipilot32/downloads/list
VROS : Eclipse + GCC Codesourcery.
  • Professional Ide editor.
  • Support Multiproject operation.
  • Support C/C++ language.
  • Editing makefile, linker script, asm code.
  • Integrated make code: make clean , make all.
  • Ready to use VROS 'C' template : ChibiOS/RT .
Link: http://code.google.com/p/multipilot32/source/browse/#svn%2Fbranches%2FRedfox74%2FChibiOS-VROS-Dist
Upcoming revision of ide: (working progress)
VRide rev 0.0.2
  • Patch the interrupt vectortable to support high denisty micro.
  • Update maple library for support of 4 serial interface , using also the serian interface connected to usb on oilpan.
VRide rev 0.0.3
VROS : Eclipse + GCC Codesourcery + OpenOCD
  • support for Jtag uploader.
  • support for Jtag debugger: step by step debug, variable watching in realtime.
  • Vros C++ template and support of MP32 library.
Framework available status of development.
3689394952?profile=original
Firmware available:
Available Firmware:
Upcoming Firmware:
  • Arducopter Mega
  • Ardupilot 2.0
Original Thread in the Forum : http://www.virtualrobotix.com/forum/topics/multipilot32-vride-and-vros
    Randy are working on ArduHely ... and are doing a lot of test on his hely . Are you seen your video ?
    In the next week i upgrade my EasyStar with Multipilot32 and Oilpan so i can start to do' some test on Ardupilot 2.0 ... I thinks that DevCore Team are doing great job on that revision of code .. I test it on Xplane and i saw a lot of new functionality available.
    No, I don't have a Quad ( I need motors and ESCs) work on Fixed Wing first (Stryker II), then a well tuned stable Heli (HDX-500 or Swift 550)
    Do you want to implement autopilot for hely or for fixwing ? are you yet testing quadcopter platform ?
    Blended Wing Body with split ailerons (duckerons) and dual motors. And conventional helicopter maybe without flybar.
    @Matthew @Mark,
    yes Matthew , the problem is that the quad is totally different from a fixed wing. So I'm evaluating what kind of approach doing for full failsafe , my idea is to implement tri core board. So the problem is to decide what approach will be correct to decide what cpu are fault and how manage actuator. I think that all the sensor could be double gps ,too
    @Mark ,
    for multitasking development is available ChibiOS on Multipilot32 if you learn more about our SO you can check www.chibiOS.org.
    What kind of drone do you like do develop ?
    Best
    Roberto
    Thanks Matthew,
    Just as I though. I ordered one to learn how to develop for multi threaded apps.
  • The schematic can be found here
    http://code.google.com/p/multipilot32/source/browse/#svn%2Ftrunk%2F...
    As far as I can see it is a direct connection.
    This platform is focused on quadrotors for now.  There is not much use for a failsafe with a quad.   If you loose the gyros and mixers you have probably lost everything.
    Roberto has a new version in design.  No idea if that adds a true failsafe.
    Roberto answers questions quite quickly on the main forum here:
    How is Fail-Safe mode implemented?
    Does a micro, Tiny XX & Mux chip to do the RC _Servo switching? Or a dedicated M3 core? and dedicated  I/O pins ?
