So here the setup;
I just graduated from Aerospace Eng, at Ryerson University in Toronto, Canada. This was build for the UAV team to compete in the USC UAV competition. At that time we were runing PiratesNG code.
Pictures from the competition:
http://www.unmannedsystems.ca/content.php?doc=169
At the competition
The first day was very windy(35 kmh!!), yet for some reason we decided to take off. and we had a scary water puddle landing, where the battery was partially submerged in water. We were lucky that the Lipo was undamaged.
The second day we learnt of a very important flaw in our system. I had a 20 amp rated switch on the main power line.... which lead to a serious power drain and a crash. Luckly, the night before we had created a frankinstien of a landing gear using carbon strips.This saved the crash (the carbon strips too most most of the impact and broke). So we removed our switch and beefed up the wiring.
The third day the weather was gorgeous, and all was looking good. We took off and went off into the wilderness. Our pilot has never flown the copter out in the open for too long so this was his first time. after we did a few circles and failing to see any targets. ( we were limited on the range for the camera) . A sudden gust forced the quad to loose altitude and plummet into some trees. But we quickly recovered it and found that we had a branch stuck on the quad. so we had to do an emergency landing and that was the end of our adventure.
Unfortunately for us the arducopter 2 code released the week after the competition, so we missed out on the autopilot code.
Here is Carlton University's Videos of the event, our quad copter is in it,
Unmanned Systems Canada Student UAV Competition 2011 from Rob Williams on Vimeo.
Arducopter 2
After we got back from the competition, I started to upgrade the firmware to 2.0.xx. During the water puddle landing we busted up our sonar. So right now i have no sonar. Our frame has warped. Jakub's frame uses very thin G10 plates so there is some serious flexing on the legs. The aluminium legs are pretty good though. Our department just got a laser cutter so I'll be busy building a new frame in the next few weeks.
Have only flown in Stabilize mode, simple seems to go crazy with yaw.
Does it need to get a gps lock for simple mode to work? and should my magnetometer show north correctly without a GPS lock?
The 2.0.28 code was really good. I was relying heavily on the auto trim flight to get it to stop drifting. With the old labview based configuration the accel offsets were changeable through xbee. That feature has been removed which is making it hard for me to get the quad level.
If i save the parameters using the planner, will the offsets also be saved?
I'm having a lot of fun working with the ArduQuad, even though sometimes i feel like is should throw it at a wall. As for the Ryerson UAV team, we are building a Fixed wing plat form, as well as a tricopter, to engage more students into the world of UAVs and ardupilot. hopefully we'll have a fleet of arducopters, helis, and planes within the year.
I'll leave you with a funny video of us trying to fly the Arducopter through a coat rack... feel free to LoL..
there are more videos of us at on our you tube channel.
Cheers,
Madhuran.
You can try the in-field level command. Hold disarm for 10+ seconds. You can adjust by propping it at different angles to get a better solution.
Jason
Comment by madhuran wilson on June 30, 2011 at 8:48pm
Comment by madhuran wilson on July 1, 2011 at 5:18am Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1285 members
677 members
24 members
4 members
8 members
Powered by
