My TMR-FC Flight Controller
- Frame
3689520481?profile=original
- Controller
3689520582?profile=original
3689520653?profile=original
3689520628?profile=original
3689520667?profile=original
- Introductions
    1. User Guide :
        TMR_FC_UM_V1_120730.pdf
    2. Sechematic :
        TMR_FC_HW_V1_120830.pdf
    3. Gerber :
        TMRFC_GB_V1_120930.rar
    4. Software :
         The software is Porting from "PX4".
         https://github.com/cctsao1008/TMR
- Hardware Features
    1. MCU :
          STM32f405RG
    2. AHRS :
          MPU6050, HMC5883, MS5611
    3. Features :
          12 channels PWM output, one PPM input and one Futaba S.BUS input,
          Built-in 10 DOF, 5 LEDs ( controlled by PCA9533/9536), GPS port ( UART / I2C),
          Auxiliary SPI and  GPIO, RF port (APC230 or BT), LiPo Voltage measure via ADC,
          Beeper for tone alarm, SWD port, SONAR, USB VCP and MSC, Micro SD ( can be read via USB),
          Light Bar LED control, Internal FLASH EEPROM emulation using sector 1, 2 and 3 ( 16KB x 3 ),
          RTC ( power keep by 3V CR1220 )
          ....... etc
    4. Stress Test VB scripts :
          Auto re-boot loop test, tone alarm loop test, ..... etc
    5. Support PX4 Qupgrade tool :
        3689520712?profile=original
- Tests :
3689520760?profile=original
3689520733?profile=original
3689520694?profile=original
3689520778?profile=original
3689520746?profile=original
3689520808?profile=original
- Boot Log :
reboot
ABCDF
nsh_romfsetc: nsh > romfs_img_len 0xFF52F09C
nsh_romfsetc: nsh > Mounting ROMFS filesystem at target=/etc with source=/dev/ram0
[boot] Initializing (HRT) 1...
[boot] Initializing (CPU) 2...
[boot] Initializing (DMA) 3...
[boot] Initializing pca953x driver
[PCA953X] on I2C bus 2 at 0x62
[TMRFC_LED] led_off, led = 0x338
[TMRFC_LED] led_off, led = 0x332
[TMRFC_LED] led_on, led = 0x334
[boot] Initializing soft SPI for the MMC/SD slot
[boot] Successfully initialized soft SPI for the MMC/SD slot
[boot] Binding soft SPI device to MMC/SD slot 0
[boot] Successfuly bound Soft SPI device to MMC/SD slot 0
[boot] Initializing SPI3
[init] MODE = autostart
[init] Looking for microSD...
[init] Card mounted at /fs/microsd
[init] tone_alarm start
[init] Reading /fs/microsd/etc/rc.txt
Detecting on board sensors on I2C bus(I2C2) ......
( 0x62 ) Have PCA9533DP
( 0x41 ) Have PCA9536DP
( 0x69 ) Have MPU6050
  Set MPU6050 auxiliary I2C bus to bypass mode......
  Detecting sensors on MPU6050 auxiliary I2C bus......
  ( 0x1e ) Have HMC5883L
  ( 0x77 ) Have MS5611
i2c: Done
[init] Start the ORB
[uorb] ready
ramtron: RAMTRON not enabled, skipping.
param: selected parameter default file /fs/microsd/params
[init] param load /fs/microsd/params
param: end of parameters
[init] Start mavlink ( 57600  /dev/ttyS1 )
mavlink: MAVLink v1.0 serial interface starting...
mavlink: DOWNLINK MODE
mavlink: UART is /dev/ttyS1, baudrate is 57600
[init] Start commander
commander: starting
commander: No RGB LED found
[fcservo] default PWM output device
<fcservo> MODE_NONE
[fcservo] starting
<fcservo> adjusted actuator update interval to 100ms
FC driver (no PWM) started
[init] Start sensors >> need to implement
[init] Start one of the estimators ( attitude_estimator_ekf ) >> wait for MPU6050 driver ready !!
[init] Start GPS >> need to implement
NuttShell (NSH)
nsh> eeprom test
RM0090 Table 5. Flash module organization (STM32F40x and STM32F41x)
[DEBUG]Check_Sector_Erased (845):SS = 0x08000000, SE = 0x08003FFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (986):Check_Sector_Erased 0  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08004000, SE = 0x08007FFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (988):Check_Sector_Erased 1  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08008000, SE = 0x0800BFFF, COUNT = 0x00004000
[DEBUG]internal_flash_test (990):Check_Sector_Erased 2  (ERASED)
[DEBUG]Check_Sector_Erased (845):SS = 0x0800C000, SE = 0x0800FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (992):Check_Sector_Erased 3  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08010000, SE = 0x0801FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (994):Check_Sector_Erased 4  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08020000, SE = 0x0803FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (996):Check_Sector_Erased 5  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08040000, SE = 0x0805FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (998):Check_Sector_Erased 6  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08060000, SE = 0x0807FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1000):Check_Sector_Erased 7  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08080000, SE = 0x0809FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1002):Check_Sector_Erased 8  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x080A0000, SE = 0x080BFFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1004):Check_Sector_Erased 9  (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x080C0000, SE = 0x080DFFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1006):Check_Sector_Erased 10 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x080E0000, SE = 0x080FFFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1008):Check_Sector_Erased 11 (DATA)
[DEBUG]internal_flash_test (1011):Warning !! This test will destroy the data stored on sector 1 and 2 !
[DEBUG]internal_flash_test (1014):1)sched_lock....
[DEBUG]internal_flash_test (1018):2)FLASH_Unlock....
[DEBUG]internal_flash_test (1022):3)EE_Init....
[DEBUG]EE_Init (146):EE_Init
[DEBUG]EE_Init (330):EE_Init >> VALID_PAGE
[DEBUG]EE_Init (345):EE_Init >> ERASED
[DEBUG]EE_Init (347):EE_Init >> FLASH_EraseSector 1
[DEBUG]EE_Init (355):Page 1 blank, skip to erase it.
[DEBUG]internal_flash_test (1025):4)FLASH_Lock....
[DEBUG]internal_flash_test (1029):5)sched_unlock....
nsh>
-log for DJI F450 :
ABCDF
nsh_romfsetc: nsh > romfs_img_len 0x80B7DC8
[boot] Initializing HRT Callout Interface
[boot] Initializing CPU Load Estimation
[boot] Initializing Serial DMA
[boot] Initializing PCA9533 and PCA9536
sercon: Registering CDC/ACM serial driver
uart_register: Registering /dev/ttyACM0
sercon: Successfully registered the CDC/ACM serial driver
[init] eeprom
eeprom: mounted EEPROM at /eeprom
sercon:: ERROR: Already connected
[uorb] ready
Try to get an USB console
nshterm [12:100]
11: + SYS_AUTOSTART: equal
Load .. 11_dji_f450
[init] TMRFC v1 on DJI F450
MAV_TYPE: curr: 1 -> new: 2
nsh: px4io: command not found
mavlink: UART is /dev/ttyS2, baudrate is 57600
<fcservo> MODE_12PWM
<fcservo> set_pwm_rate 0 50 50
[fcservo] starting
<fcservo> adjusted actuator update interval to 20ms
<fcservo> MIXERIOCRESET
<fcservo> MIXERIOCLOADBUF
<fcservo> new MixerGroup
<fcservo> set_pwm_rate 0 50 400
<fcservo> set_pwm_rate fff 50 400
<fcservo> adjusted actuator update interval to 2ms
[uorb] already loaded
uORB started
ADC
<adc> init done
[MPU6050] on I2C bus 2 at 0x69
[MPU6050] Ready.
[HMC5883] on I2C bus 2 at 0x1e
[HMC5883] Ready.
[MS5611_I2C] on I2C bus 2 at 0x77
[MS5611] Ready.
[sensors] Initializing..
sensors_task: using system accel
sensors_task: using system gyro
sensors_task: mag cal status changed
preflight_check [38:100]
commander: starting
sdlog2: logging to directory: /fs/microsd/sess003
sdlog2: log buffer size: 16384 bytes.
[gps] starting
[gps] failed to open serial port: /dev/ttyS3 err: 2
Extended Kalman Filter Attitude Estimator initialized..
position_estimator_inav: started.
multirotor_att_control: starting
multirotor_pos_control: start
multirotor_pos_control: started
sdlog2: start logging.
sdlog2_writer: logging to: /fs/microsd/sess003/log001.bin.
position_estimator_inav: init baro: alt = 45.242
position_estimator_inav: main loop started.
  • good thinks
  • nsh> tests all
    Running all tests...
    [led] STARTING TEST
    LED test completed, no errors.
    [led] PASS
    [int] STARTING TEST
    --- 64 BIT MATH TESTS ---
    success: 354156329598 * 5 == 1770781647990
    --- 32 BIT / 64 BIT MIXED MATH TESTS ---
    success: 64bit calculation: 50 * 2147483647 (max int val) == 107374182350
    SUCCESS: All float and double tests passed.
    [int] PASS
    [float] STARTING TEST
    --- SINGLE PRECISION TESTS ---
    The single precision test involves calls to fabsf(),
    if test fails check this function as well.
    success: sinf(0.0f) == 0.0f
    success: sinf(1.0f) == 0.84147f
    success: asinf(1.0f) == 1.57079f
    success: cosf(1.0f) == 0.54030f
    success: acosf(1.0f) == 0.0f
    success: sinf(0.1f) == 0.09983f
    success: sqrt(2.0f) == 1.41421f
    success: atan2f(1.0f, 1.0f) == 0.78539f
    success: printf("%8.4f", 0.553415f) == 0.5534
    success: printf("%8.4f", -0.553415f) == -0.5534
    --- DOUBLE PRECISION TESTS ---
    success: 1.0111 * 2.0 == 2.0222
    success: (float) 1.55f == 1.55 (double)
    success: sin(0.0) == 0.0
    success: sin(1.0) == 0.84147098480
    success: atan2(1.0, 1.0) == 0.785398
    testing pow() with magic value
    (44330.0 * (1.0 - pow((96286LL / 101325.0), 0.190295)));
    success: result: 428.2293
    success: printf("%8.4f", 0.553415) == 0.5534
    success: printf("%8.4f", -0.553415) == -0.5534
    [float] PASS
    [sensors] STARTING TEST
    Running sensors tests:
    sensor: accel
    ACCEL: test start
    ACCEL accel: x: -0.5675 y: 0.5848 z: -9.8895 m/s^2
    OK: ACCEL passed all tests successfully
    sensor: gyro
    GYRO: test start
    GYRO rates: x: 0.0051 y: -0.0411 z: 0.0029 rad/s
    OK: GYRO passed all tests successfully
    sensor: mag
    MAG: test start
    MAG values: x: -1.0303 y: -1.0202 z: 1.0330
    OK: MAG passed all tests successfully
    sensor: baro
    BARO: test start
    BARO pressure: 995.7500 mbar alt: 146.7016 m temp: 36.1600 deg C
    OK: BARO passed all tests successfully
    [sensors] PASS
    [adc] STARTING TEST
    10: 38 15: 3 16: 14 17: 0 18: 0
    10: 69 15: 0 16: 11 17: 0 18: 0
    10: 69 15: 0 16: 8 17: 0 18: 0
    10: 67 15: 0 16: 10 17: 0 18: 0
    10: 69 15: 0 16: 6 17: 0 18: 0
    tests: ADC test successful.
    [adc] PASS
    [tone] STARTING TEST
    Alarm 1 (disable with: tests tone 0)
    [tone] PASS
    [sleep] STARTING TEST
    100 100ms sleeps
    Sleep test successful.
    [sleep] PASS
    [time] STARTING TEST
    Maximum jitter 3us
    [time] PASS
    [perf] STARTING TEST
    perf: expect count of 4
    test_count: 4 events
    perf: expect count of 1
    test_elapsed: 1 events, 355us elapsed, min 355us max 355us
    perf: expect at least two counters
    ms5611_buffer_overflows: 18972 events
    ms5611_comms_errors: 9 events
    ms5611_measure: 25333 events, 3909783us elapsed, min 150us max 214us
    ms5611_read: 25332 events, 8071370us elapsed, min 236us max 11347us
    hmc5883_buffer_overflows: 31653 events
    hmc5883_comms_errors: 0 events
    hmc5883_read: 31658 events, 10631825us elapsed, min 330us max 835us
    mpu6050_read: 50668 events, 28114551us elapsed, min 537us max 780us
    ADC samples: 765 events, 2831us elapsed, min 3us max 31us
    sensor task update: 0 events, 0us elapsed, min 0us max 0us
    [perf] PASS
    [param] STARTING TEST
    tests: parameter test PASS
    [param] PASS
    [bson] STARTING TEST
    tests: PASS: decoder: bool1
    tests: PASS: decoder: int1
    tests: PASS: decoder: int2
    tests: PASS: decoder: double1
    tests: PASS: decoder: string1
    tests: PASS: decoder: data1
    [bson] PASS
    [file] STARTING TEST
    tests: 512KiB in 8370313 microseconds
    SD writes: 1024 events, 8367518us elapsed, min 6506us max 50779us
    tests: running unlink test
    tests: unlink iteration #0
    tests: unlink iteration #1
    tests: unlink iteration #2
    tests: unlink iteration #3
    tests: unlink iteration #4
    tests: unlink iteration #5
    tests: unlink iteration #6
    tests: unlink iteration #7
    tests: unlink iteration #8
    tests: unlink iteration #9
    tests: unlink iteration #10
    tests: unlink iteration #11
    tests: unlink iteration #12
    tests: unlink iteration #13
    tests: unlink iteration #14
    tests: unlink iteration #15
    tests: unlink iteration #16
    tests: unlink iteration #17
    tests: unlink iteration #18
    tests: unlink iteration #19
    tests: unlink iteration #20
    tests: unlink iteration #21
    tests: unlink iteration #22
    tests: unlink iteration #23
    tests: unlink iteration #24
    tests: unlink iteration #25
    tests: unlink iteration #26
    tests: unlink iteration #27
    tests: unlink iteration #28
    tests: unlink iteration #29
    tests: unlink iteration #30
    tests: unlink iteration #31
    tests: unlink iteration #32
    tests: unlink iteration #33
    tests: unlink iteration #34
    tests: unlink iteration #35
    tests: unlink iteration #36
    tests: unlink iteration #37
    tests: unlink iteration #38
    tests: unlink iteration #39
    tests: unlink iteration #40
    tests: unlink iteration #41
    tests: unlink iteration #42
    tests: unlink iteration #43
    tests: unlink iteration #44
    tests: unlink iteration #45
    tests: unlink iteration #46
    tests: unlink iteration #47
    tests: unlink iteration #48
    tests: unlink iteration #49
    tests: unlink iteration #50
    tests: unlink iteration #51
    tests: unlink iteration #52
    tests: unlink iteration #53
    tests: unlink iteration #54
    tests: unlink iteration #55
    tests: unlink iteration #56
    tests: unlink iteration #57
    tests: unlink iteration #58
    tests: unlink iteration #59
    tests: unlink iteration #60
    tests: unlink iteration #61
    tests: unlink iteration #62
    tests: unlink iteration #63
    [file] PASS
    T E S T S U M M A R Y
    ______ __ __ ______ __ __
    /\ __ \ /\ \ /\ \ /\ __ \ /\ \/ /
    \ \ __ \ \ \ \____ \ \ \____ \ \ \/\ \ \ \ _"-.
    \ \_\ \_\ \ \_____\ \ \_____\ \ \_____\ \ \_\ \_\
    \/_/\/_/ \/_____/ \/_____/ \/_____/ \/_/\/_/
    All tests passed (12 of 12)
  • Admin
    Good Work.  Keep us updated with the maiden flight.  Thanks for sharing your work.
  • Fix UART nsh lost connection, when nsh issued a msconn command
    NOW, uart nsh and USB MSC can be used in parallel.
    Fix UART nsh lost connection, when nsh issued a msconn command. · cctsao1008/TMR@b7944cd
    NOW, uart nsh and USB MSC can be used in parallel. Signed-off-by: cctsao1008 <chiacheng.tsao@gmail.com>
