3689600589?profile=original
Hey guys!
With your help we have successfully funded the Navio campaign and reached three stretch goals. Everyone who pledged for Navio or Navio Raw board on Indiegogo will additionally get:
  • GPS\GLONASS antenna
  • Pack of DF13 wires
  • Onboard FRAM chip
We also plan to develop and release a special case for Navio that can be 3D printed and used to protect it.
Navio campaign is still active and you can get one for yourself on our Indiegogo page.
Navio was primarily designed to be used with Raspberry Pi, but there are a couple of alternative boards that duplicate the form-factor or Raspberry Pi and should also be compatible with Navio. These boards are:
Banana Pi
3689600424?profile=original
Created by Lemaker.org, the Banana Pi duplicates the layout and footprint of the Raspberry Pi and packs more power and connectivity. One of the downsides is that 26-pin header was moved closer to the RCA connector and to fit Navio properly you will have to desolder it. Actually, we remove RCA connector from Raspberries anyway to reduce the size.
SOC: Allwinner A20 Cortex-A7 Dual-Core clocked to 1GHz
GPU: ARM Mali400MP2
RAM: 1GB
Ports: 1000Ethernet, SATA, HDMI, LVDS, CSI, 2xUSB host, 3.5 audio
Features: IR-receiver, CAN, OTG connector, Microphone, Power switch
HummingBoard
3689600602?profile=original
Developed by Solid-Run, the creator of the CuBox product line with which the HummingBoard is similar in features. Design and layout are also the same as in Raspberry Pi, but even more powerful with quad-core processor and 2GB of memory.
SOC: Quad-core Cortex-A9 Freescale i.MX6 clocked to 1GHz
GPU: Vivante GC2000
RAM: 2GB
Ports: 1000Ethernet, mSATA, HDMI, LVDS, CSI, mini-PCI-E, 2xUSB host, 3.5 audio
Features: Wi-Fi, Bluetooth, FlexCAN, Real-time clock, IR-receiver, SPDIF out
We are awaiting arrival of these boards and will post more information as soon as we test them.
More:
Navio on Indiegogo
Emlid blog
Banana Pi
HummingBoard
  • Greg, the simplest way to connect Navio to BBB is to use male-to-male jumper wires for I2C and SPI buses.
    Even simpler way - use Raspberry Pi instead of BBB. They are not that much different, but Navio fits well on RPi.
  • Is it possible to connect Navio to BBB, without much trouble?
  • Chris, thanks! We are working on the manufacturing to deliver as fast as possible.
    Congrats! Can't wait to get mine.
