New ArduCopter Accessory - Tilt/Roll Cam Mount
3689419241?profile=original
For those of you who use a camera on ArduCopter there's a new accessory being added to the store today. It's a til-roll camera mount that stabilizes small cameras (up to about 75 grams) and keeps the image straight up and down while ArduCopter is maneuvering to maintain position and orientation. The kit is $20 and can be found here. Please note that the kit does not include a camera or servos! We recommend you use HS-55 servos or any other sub-micro servo in the same size. The kit does work out of the box with ArduCopter code - plug the servos in to channels 5 and 6 for automatic stabilization. Happy flying!
3689419481?profile=original
3689419603?profile=original
  • Sorry I was thinking of Arducopter, for Arduplane you do need to compile the code yourself with the camera tracking library included.
  • Jeff is this available in Arduplane program?
    Stabilization is the default mode that the code is in, you can just download the latest version of code from the mission planner and it will stabilize on channels 5 and 6 automatically without editing any code."
  • Stabilization is the default mode that the code is in, you can just download the latest version of code from the mission planner and it will stabilize on channels 5 and 6 automatically without editing any code.
    Actually in the bixler and ez star chassis you can set it up both as a roll/tilt or pan/tilt. Assembly instructions for both configurations are on the product page (http://stuff.storediydrones.com/Easy%20Star%20-%20Bixler%20Chassis%...)
    http://stuff.storediydrones.com/Easy%20Star%20-%20Bixler%20Chassis%20Manual
  • Yes this still works with APM1 - when set up for Arduplane on a bixler or easystar chassis, the mount only stabilizes pan and tilt; while on Arducopter it stabilizes tilt and roll. The only difference is the orientation that you attach the mount on the chassis of either frame.
  • The assembly guide is now available here: http://stuff.storediydrones.com/TiltRollMount.pdf
  • I guess the tilt while in stabilise will be fairly minimal anyhow. The plan is to use the video downlink and xbee's with Michael's Mission Planner HUD so perhaps this will be easier to see where I am going?
  • There are two possibilities here - first you can use the ground-side OSD from Michael Oborne's ground station and your xbee telem link to fly with an artificial horizon. The real benefit will be when you have ACM flying stabilization or waypoints while you direct the quad which way to point!
  • Just have to ask, if you are using that small camera for your FPV view wouldn't it be even harder to stabilise the quad when you do not see the attitude of the quad being matched to where the camera is pointing? I though the idea of this type of auto camera stability is to record your video on a secondary on board camera like a GoPro HD without seeing all the attitude changes of the quad on the final video?
  • We attached the tilt servo directly to the roll servo. If you use bearing supported metal gear servos it works fine, but the servo resolution has to be good or you will get jitter in video feed. For FPV though it works great.
