Here's a cool new product from the Maker Shed: Blink RC. It's a wifi-to-RC board, which can let you replace your RC gear with a smartphone or other wifi-enabled computer. From the announcement:
The BlinkRC from the Maker Shed replaces your standard remote control receiver in your car, plane, or boat, and allows you to control it with your smart phone. The more adventurous can try creating an application on your computer that takes advantage of the open messaging protocol and the BlinkRC’s (3) output channels and (2) analog input channels. Now you can control a variety of different servo’s and sensors from almost anywhere that has WiFi or Internet access.
A few thoughts:
1) Looks good! But...
2) $125!!!
3) Wifi range limitation makes it inappropriate for most aircraft applications
4) Not open source :-(
Here are the full specs:
- 802.11b/g/n connectivity
- Onboard low-profile WiFi chip antenna
- Onboard U.FL-R-SMT-1 external WiFi antenna connector
- Infrastructure or Ad-Hoc Modes
- Transmit range up to 330' depending on environmental / antenna considerations
- Requires 3.5vdc to 5.5vdc regulated input (typically from ESC)
- Three (3) Output Channels for Servo/ESC control
- Two (2) 0-20v analog input channels with 8-bit resolution
- Reverse Polarity Protection on Battery input
- Optional plastic enclosure
- FREE download of iPhone controller app
- FREE download of PC compatible controller app
- FREE download of Droid controller app (coming soon)
- FREE download of Blackberry controller app (coming soon)
- Dimensions: 2.8" (L) x 1.0" (W) x 0.25" (H)
- Weight: Approximately ~4oz
- Outputs: Three (3) Universal/Futaba J Style Connectors
- Inputs: Two (2) .1" Header Connectors w/ +5V and GND Available for Sensors
Can't believe it has no data connection. It just does PWM. That's the RC world & people actually buy this stuff because they don't know how to go from wifi to PWM. Now those $parkfun $50 wifi - UART boards that only do 1 megabit look like a steal.
Actually, this is the $50 wifi module from $parkfun. & every time you hit "buy", $parkfun's inventory goes down by 1.
