ODROID + Flip32 Mini Quadcopter, Part I: Basic Build
Following on the work described in an earlier post, we wanted to build an inexpensive quadcopter that could be controlled by an onboard ODROID U-3 single-board computer.
We were happy with the Naze32 / Baseflight / Multiwii Serial Protocol, but were delighted to discover the new Flip32 flight controller from Ready To Fly Quads. At $16, the Flip32 is even more absurdly inexpensive than the $25 Naze32! But the real advantage we saw in the Flip32 was its soldering holes for not only UART (like the Naze32), but also I2C (for sensor input) and SWD (for firmware debugging).
Based on our success with the inexpensive ZMR250 frame from Multirotor Superstore,
we decided to go with the same basic setup, swapping in the Flip32 for the Naze32. (This excellent video has a side-by-side comparison for anyone interested, and this video series helped us get started with the build.)
Two other requirements were: (1) a secure mount for the Flip32 and ODROID U-3 and (2) a cleaner power distribution, to avoid the messiness shown below from the homebrew squid distro we did on our previous build:
For the secure mount, we decided to take the plunge into 3D printing, with the goal of having our first print job be a simple rectangular slab that would support both the Flip32 and the ODROID. For the power distro, we opted for the inexpensive Quadcopter Power Distribution Board from HobbyKing – a little big for this vehicle, perhaps, but featuring pre-soldered 3mm bullet connectors, a vibration-isolating foam pad on the bottom, and widely-spaced holes that proved helpful for mounting the Flip32 and ODROID.
Here are the basic parts and their costs rounded up to whole dollars, excluding the 3D printing, zip-ties,
jumpers, heat-shrink tubing, E6000 adhesive, and other stuff we already had in the shop. Naturally you'll
want to order extra ESCs, motors, and props, but this gives you a basic idea of the cost:
  • Multirotor Superstore:
    • ZMR250 Carbon Fiber Mini Quadcopter frame 1 @ $40
    • MS 12amp ESC (SimonK RapidESC) 4 @ $16
    • Airbot Titan 2204 2300kv Brushless Motor 4 @ $20
    • 3S 1300MAH 35C LIPO BATTERY 1 @ $16
    • 3x40 Right Angle Pin Header Set 1 @ $3
    • 2x40 Right Angle Pin Header Set 1 @ $2
  • ReadyToFlyQuads:
    • Flip32 Flight Controller 1 @ $16
  • HobbyKing:
    • FrSky VD5M Receiver 1 @ $12
    • Quadcopter Power Distribution Board 1 @ $4
    • Micro Server Connectors (5 per bag) 1 @ 2
    • Gemfan 5030 Multirotor ABS Propellers (pair) 2 @ $2
  • McMaster-Carr:
    • 10mm M3 male-female nylon hex standoffs 4 @ $2
    • 6mm M3 male-female nylon hex standoffs 4 @ $2
    • M3 nylon hex nuts, 100 pack 1 @ $11
    • M3 nylon pan-head machine screws, 1 pack 1 @ $8
  • Lowes:
    • 7/32" six-point socket head 1 @ $3
  • TOTAL $281
Here's a quick pictorial run-through of the build:
The ZMR25 frame, minus top plate, FPV plates, legs, and other stuff we didn't use
Adding the Velcro one-wrap for the battery, before sandwiching the plates together
The power distro,with 10mm standoffs
This inexpensive 7/32" socket-wrench head from Lowes was the right size for holding the locknuts in place while we bolted together the frame.  We prefer metric, but none of the metric sizes they had was right for deez nuts!
The power distro, glued to the frame with E6000 (a.k.a. Goop)
Power distro battery cables passed through to the bottom of the frame, then EC-3 connector soldered on
Motors mounted and ESCs Velcroed on the frame and connected to the distro, wires secured by cable tie
Our 3D-printed mount for attaching the flight controller to the power distro. We put our school's logo
(the Trident) on top for fun. STL available here.  Our next version will be longer and have additional holes for mounting the ODROID U-3.
We designed and 3D-printed legs  for extra clearance and stability
The Flip32 with headers soldered on for ESCs, receiver, and UART / I2C
The Flip32 on our 3D-printed mount
Neoprene tubing on power distro standoffs, for additional vibration isolation
All wiring completed, including FrSky VD5M receiver
Closeup side view
When the students return on Monday we'll have the maiden flight with this vehicle, in “Dronehenge”, our tiny aerodrome in the Washington and Lee Science Center. Those standup desks make a nice safety barrier! If we're successful, there will be a Part II to this post, showing how to mount the ODROID.
Dronehenge!
Comment by Harry on August 10, 2015 at 6:31am
I bookmarked this!  I'm working with the Flip1.5 as exercise, and it too is about $15.00 .  Cheap, cheap, cheap is good, good, good.
When I'm ready, I will dig in to what you've been doing.  My first exercise was to adapt ArduIMU 1.9.8 to the Flip1.5 just to see if I could since its i2c and not spi and sensor orientation is different.  After some work, I got it.
The ODROID will be a higher hurdle for me, but I'm starting to see the appeal.
Comment by André Carvalho on August 10, 2015 at 7:35am
Good Job!!!
And thanks for the Tutorial!! ;)
Comment by Simon D. Levy on August 12, 2015 at 12:53pm
Thanks, guys!  We just did the maiden flight, and it was pretty smooth.
Comment by Roberto Colella on September 29, 2015 at 5:37am
Very good job...could you tell me the flight time obtained with this setup?
tks!
Comment by Anyasz on December 2, 2016 at 12:32am
There are couple of SBC's which are based on Freescale SoC, I would recommend TGraperain Custom single board computer which is off-the-shelf embedded platform that consists of a system on module and a carrier board. The platform can be scaled up to accommodate future requirements by switching to another pin-compatible SOM based on latest processors. You can choose any SOM and a compatible carrier board, to create a customized SBC that is tuned to your needs. These platforms can be used for both engineering development and mass-production.
Comment
