One ESC is not like the others. Why?
I've been having a lot of fun with my new ArduCopter. My initial flight was interesting - due to me switching flight modes with the throttle up it jumped off the floor and flew straight at me. I now have a nice scar on my shoulder as a memento of that first flight :-)
3689392108?profile=originalSince then I've been taking things a bit more carefully. The above photo shows the copter tied down to a 20 litre tin of paint, so it can only rise about 10cm off the tin. It will be released from its string prison once I've got some of the glitches out.
The particular glitch that has me puzzled at the moment is ESC callibration. During some testing I suspected that the motors were not all running at the same speed, so I wrote this little tester and hacked it into the ArduCopterMega trunk:
static void run_testmode(void)
Serial.println("Running motor test");
for (uint16_t thr=1100; thr<=2000; thr += 100) {
for (unsigned char i=0; i<4; i++) {
Serial.printf_P(PSTR("motor test %u thr=%u\n"),
(unsigned)i, (unsigned)thr);
APM_RC.OutputCh(i, thr);
delay(1000);
APM_RC.OutputCh(i, 1000);
delay(1000);
if (Serial.read() != -1) {
Serial.println("terminating motor test");
for (unsigned char j=0; j<4; j++) {
APM_RC.OutputCh(j, 1000);
return;
Serial.println("Finished motor test");
The code runs each of the motors in turn, starting at a PWM value of 1100 and rising to 2000. As I suspected, it showed that one of the ESCs (the one driving the front motor) is calibrated quite differently from the other 3. The front
ESC runs at 1100, when the other 3 don't run at all, and doesn't run at all at 1900 or 2000, while the other 3 do run up to and incuding at 2000.
I have been through ESC calibration, using this bit of code, which is based on some code from the ArduPirates tree:
static void calibrate_ESCs(void)
Serial.println("Disconnect battery then hit enter");
while (Serial.read() == -1) ;
Serial.println("Now connect your battery. After beep beep, hit enter");
while(1) {
APM_RC.OutputCh(0, 2000);
APM_RC.OutputCh(1, 2000);
APM_RC.OutputCh(2, 2000);
APM_RC.OutputCh(3, 2000);
APM_RC.Force_Out0_Out1();
APM_RC.Force_Out2_Out3();
delay(20);
if (Serial.read() != -1) break;
Serial.println("wait for beep then hit enter again");
while(1) {
APM_RC.OutputCh(0, 900);
APM_RC.OutputCh(1, 900);
APM_RC.OutputCh(2, 900);
APM_RC.OutputCh(3, 900);
delay(20);
Serial.println("disconnect your battery and then hit enter again");
If I understand correctly, that should have calibrated all 4 ESCs to the same value, but it didn't seem to work.
Does anyone have any suggestions? Is it just a matter of replacing the ESC that is out of kilter with the others?
UPDATE: I've solved it! The problem was I had misunderstood the importance of the timing in the ESC calibration instructions. I read the ESC manual, and noticed that the procedure for entering programming mode is actually the same as the initial steps for doing throttle callibration. The only difference is how long you wait after connecting the battery the first time. I was beiing "conservative" and waiting several seconds, and the ESCs were entering programming mode instead of doing throttle calibration.
I now have my 4 ESCs calibrated correctly, and it hovers quite nicely in its string prison. I will be able to try a real flight now, and see if it lasts a bit longer than the first one!
    i'm using the default ESC settings, but I manually calibrated by connecting each ESC in turn to chan3 on the RX and going through the calibration sequence for each separately. That makes it much easier to hear the beeps on each ESC, so know you its taken the calibration correctly
    a few extra notes:
    1) when calibrating, don't wait too long for the beeps, or it goes into programming mode instead of calibration mode. When that happens it does a rising series of chimes
    2) it won't reliably calibrate if the low end of your throttle range is too high. I had mine at 1500:2000 and found I could not calibrate reliably. I changed the TX settings to 1000:1700 and it became much more reliable
    I've found a PDF of the manual here: http://www.poids-plume-rc.com/noticesdysetbran/esc40adysv2.pdf
    I've got the manual for that one here. I'll scan it in
    Michael, which ESC do you have? (what is written on the side?)
    Hi Tim,
    The pandaboard will be mainly used on a 3m plane we're building for the outback challenge. I might try and fit it on the ArduCopter as well, or I might use a smaller ARM board if I find I can't securely mount the pandaboard. The ARM board is for mission control and image recognition (we have a small ptgrey camera we will be using). I need to learn to fly the copter first though :-)
    A nook would be a fun controller! I did think about trying to use my nexus one as a controller, but I'll probably leave that till I've got everthing else sorted out.
    Cheers, Tridge
  • Also, I have to do the same thing , I will not be using a transmitter either... Trying to use a color nook for the controller...
  • I see the pandaboard next to the quad... I was thinking of going that direction for 802.11g, but I see that it will not fit at all.  The beageboard is going to get a TiW (WLink module) sometime at the end of the month...
    Are you going to use the pandaboard?
    First successful flight! My mother in law came over and offered to hold the camera for me. This is the first time I've flown a RC aircraft without having to buy new parts afterwards :-)
      http://photos.tridgell.net/v/CanberraUAV/arducopter/VID_20110304_13...
    hopefully I'll learn how to control it a bit better with a few more flights. I think some time on the simulator would be worthwhile :-)
    Hi Jani,
    The reason I calibrate with a function hacked into the ACM code and not with my transmitter is that one of my aims is to fly the copter with no RC transmitter. Doug has accepted a patch from me which allows control of the RC input channels over mavlink, and I have a program called mavproxy that allows me to precisely control the PWM values of each channel using a keyboard.That program has commands like "arm", "disarm", "throttle N", "roll N" etc, and can also control flight modes by doing things like "switch 3" to switch to flight mode 3.
    The UAV project I'm involved in needs completely automated flight, with control from a ground station at a range well beyond what a normal 2.4GHz RC transmitter can do. That project is using a plane, but I'm testing out the software with my copter.
    I'm now quite happily flying my copter in stable or FBW mode with keyboard control, with commands going over mavlink via an Xbee. So far its flying within a little "string prison", but it will soon be let off its leash (I'd like another person to be getting a movie of it when I first take off, which is why I'm not out flying it now).
    The principal problem I had with calibration was the timing. I waited too long after the initial beeps when calibrating before dropping the PWM values being sent to the motors. I didn't recognise the little sing song beep series that I heard as "ESC is entering programming mode", and assumed that it was the right set of beeps for setting throttle range. It all became clear when I carefully read the ESC manual and realised that the procedure for entering ESC programming mode and the procedure for doing throttle calibration is so similar - it just differs by timing.
    It might be an idea to have a mp3 of the noises that the ArduCopter ESCs make for setting throttle range, and the noise that it makes when entering programming mode on the ESC calibration page on the wiki. I'm sure someone else will eventually hit the same problem as me :-)
    Cheers, Tridge
