Parts Received - Post 1 of 2
3689590628?profile=original
Hey Guys
I collected everything from the supplier today. Below are some photos of what I received
***************************************Frame***************************************
3689590641?profile=original
2 X RC Timer 450 Legs Red
2 X RC Timer 450 Legs Black
2 x RC Timer Spider Base plates
4 X Black Metal Stand-ups
1 X Camera Mount Plate
1 x GoPro Mounting Plate
5 x Rubber Vibration Dampers
Some Screws
***************************************Landing Gear***************************************
3689590751?profile=original
4 X Nylon RC Timer Spider Landing Gear legs
Some Screws
***************************************Controller Board etc***************************************
3689590765?profile=original
1 x RC Timer Arduflyer 2.5.2 with pin headers and cables
1 x RC Timer CN06 with cables
1 x Power Distribution Board
1 x RcTimer 6A UBEC (5 / 6V)
5 x Servo Leads
2 x Battery Straps
***************************************AV Dome***************************************
3689590686?profile=original
1 x Plastic Dome
1 x MiniUSB Cable (Male to Female)
1 x Header Pins
4 x White Nylon Standups - Long
4 x White Nylon Standups - Short
4 x Rubber vibration Dambers
1 x Capacitor
1 x Buzzer
1 x Carbon Fiber Flight Controller mounting plate
1 x Aluminium Mounting plate
Some screws
***************************************Motors***************************************
3689590786?profile=original
4 x RC Timer 2830/12 850Kva
***************************************ESC***************************************
3689590857?profile=original
4 x Turnigy MultiStar Opto 30A ESC
For Some reason I cannot add more photos to this post, So I'll Create another post with the rest of the Stuff.
  • Should have went with the Afro ESCs from the start. I was surprised to see you were going with a kit after you made your announcement. I thought you were going to build the quad from that picture. Oh well =)
  • Hi Mattew
    I might flush them. I have read about the SimonK by have not checked out the process. Something I will look into when I get there for sure.
  • are you gong to flash your ESCs to SimonK? I've seen a lot of comments where people say that the default firmware on the ESCs has the refresh rate too low so the quad feels "sluggish" and unresponsive. apparently it gets a lot zippier with the SimonK
