Precision Land ArduCopter Demo
TURN UP THE VOLUME!!! THE AUDIO IS QUIET!!!!
For the last few months I've been working on vision assisted landing for ArduCopter. The hope is to provide a means of landing a multirotor in a precise matter which is currently not attainable with GPS based landing supported by ArduCopter.
The development of this software was stimulated by Japan's recent effort to increase the use of UAV's for Search and Rescue. More can be read about that here!!! This sub-project of the S&R is being funded by Japan Drones, a 3DR retailer, and Enroute, also a 3DR retailer and a member of the DroneCode Foundation.
This specific feature, precision land, is a very small part of the large project and is designed for Multitrotor recovery. The idea is to fly a Multirotor to a disaster zone, survey the land, and relay intel(such as pictures) back to a base station. The base station may be a couple of miles away from the disaster location so precious flight time, and ultimately battery, is used to fly the copter to and from the disaster location. Multirotors are not known for their lengthy flight times, so the more battery that can be conserved for surveying and not traveling is critical for a successful mission.
That's where the precision land comes in. The idea is to station rovers, or unmanned ground vehicles, near the disaster location. These rovers will have a landing pad on top for a Multirotor. That way a Multirotor can use all of its battery to survey an area, land on top of a rover, and hitch a ride back to the base station on the rover.
The specifics:
Autopilot: Pixhawk with ArduCopter 3.2
Companion Computer: Odroid U3
Camera: Logitech c920
Vision algorithm: OpenCV canny edge detection, OpenCV ellipse Detector, my concentric circle algorithm(real simple)
Performance(on four cores): Process images at 30+ fps in good light and 10 fps in low light. Performance is limited by camera exposure not the Odroid's processing power!
The future:
1. I hope to have my first live test in a week or so. More testing needs to be done in the simulator to check all the edge cases and make the landing logic more robust.
2. Integrate the code more closely with ArduCopter code. Currently the companion computer takes control of the aircraft when it is in GUIDED mode. The hope is to have the companion computer take control in landing modes(RTL).
3. Check the performance on other companion computers: Intel Edison, BeagleBoneBlack, Raspberry Pi(maybe).
The code:
The code can be found on my github. Be cautious!
Thanks to Randy Mackay for helping me integrate the code with ArduCopter.
Daniel Nugent
  • http://diydrones.com/profiles/blogs/precision-land-arducopter
    An update for anyone that is interested.
    Daniel
  • What you mentioned is possible. Hopefully we will see more visual navigation applications integrated with Arducopter in the near feature. This could allow for a more multipurpose and modular vision system.
    I am currently working out some interesting bugs but once I feel comfortable flying it then I will put a wiki together for others to try at their own risk. End of March at the latest.
  • @Dylan
    The hope is to have this feature closely tied to the Ardupilot code base someday. The vision algorithm is still in its infancy but I have already experimented with creating unique targets using varying ring spacing, like a circular bar code.
    @Doug
    Maybe someday. Currently it is not designed to perform that task. There are two parts to the program: The vision algorithm, which identifies a target in an image; and the controls logic, which determines how the robots reacts to what is in the image. In this case the controls logic lands the Multirotor on the target. Someone could use a similar(or same) vision algorithm with different controls logic to do a precision drop. However, that is outside the scope of this current project.
  • Can this software be used to perform precision drops?
  • So far I haven't noticed any major issues with the rolling shutter problem but I haven't done a ton of testing. Still in the prototyping phase. Definitely something to look out for.
    Ardupilot was chosen because it meets the larger project requirements(S&R). Also Ardupilot reaches a larger user base and is built off the PX4 project.
  • @pal
    Very cool. Haven't done a ton of research into other cameras. The guys at ETH Zurich use an mvbluefox-mlc.
  • Thanks for the good tech as always John.
  • nice work would be cool if you recharged on ground rover
  • @David,
    Environmental conditions are a real concern. I'd love to hear more about your offline tests.
  • Congrats, Daniel, great job!
    I've been working on a very similar vision system for the last months... but of course my implementation is not as close to integration with ArduCopter as yours! I'm using the same landmark concept (a set of concentric rings) and probably the same (or very similar) detection algorithm.
    I currently have a fully functional optical sensor working on Raspberry Pi (with its Raspi camera) which also runs on Gumstix Overo and a Logitech webcam. I will port it to Beaglebone Black, and also to Odroid when I have one at hand. It is now working in "open loop" mode, meaning it can be controlled from the autopilot, but its information is not used for navigation yet: I'm running test flights for building a dataset of captured landmark images in different real conditions.
    My goal is optimizing the landmark recognition algorithm to cope with real-life conditions (you mention one in your post: low light; but also sun reflections, shadows, etc.). In order to attain this, I'm currently running offline tests on the captured dataset using different detection algorithms. The rationale behind this is that vision detection works fine in lab conditions, but is quite sensitive to illumination, motion blur and other factors: the recognition algorithm must be resilient to these real conditions.
    I'd love to share the details and collaborate if you are interested. I would also love to know more details on several integration aspects (for example, the communication protocol between the companion computer and ArduCopter: I have a working protocol defined, but you surely have very interesting information on this).
