R-Line 850mAh 95C 4S Racing Drone Battery
As we know, Tattu R-Line battery is specifically designed for professional FPV racing competitions, they are more powerful t
han any graphine battery. Higher capacity, lower internal resistance and lower landing temperatures won the pilots’ love. Now I found Tattu r-line released 850mAh 4s 95c racing drone battery
Tattu R-Line 850mAh 14.8V 95C 4S1P Lipo Battery Pack with XT30 plug has full capacity and discharge rate. It is a high discharge rate FPV racing lipo battery. The 95C gives you enough power under load. It is very compact in size and very light in weight. Works perfect with your Multirotor FPV from size 100 to 180.
Specifications:
Minimum Capacity: 850mAh
Configuration: 4S1P / 14.8V / 4Cells
Discharge Rate: 95C
Max Burst discharge Rate: 190C
Net Weight(±20g): 104g
Dimensions: 61mm Length x 31mm Width x 31.5mm Height
Charge Plug: JST-XHR-5P
Discharge Plug: XT30
Compatible with:
Shop here: https://www.genstattu.com/ta-rl-95c-850-4s1p-xt30.html
Comment
