Comment by Jake Bayless on August 17, 2012 at 12:59pm Nice!
I'd like to meet up and compare notes. Can't help but notice that mountain in the background as a well-known local spot :-) Great to find others in the 'hood.
~jake
Comment by Jonathan M on August 17, 2012 at 8:29pm Wow, awesome rig! What flight controller are you using?
Comment by Jordi Orlando on August 17, 2012 at 11:36pm Wow, impressive! What motors are you using? They sound really quiet.
Very nice! It does seem quiet, we're you using a mic when filming?
Comment by Bill Landers on August 18, 2012 at 10:55am Hey Gang,
I've been working with Ziv Marom, who is the UAV expert. His contact info can be found here! http://www.zminteractive.com/
Comment by Amilcar Lucas on August 18, 2012 at 11:41am Finally, an edited video with comments !!!
Hint to all others out there: edit the video before you post, remove the parts that are not interesting. And Explain what you are doing while you are doing it !!
Comment by Ziv Marom on August 18, 2012 at 6:47pm Hey Bill, thanks again for posting the video!! Jonathan - the boards are from mikrokopter, i had to re-program to connect the 12 motors to work together, i still have to fine-tune it, ill post more video soon, with some heavier payload... ;) we did more videos today with Realocate, will post these soon!
Cheers!
Ziv
Comment by Ziv Marom on August 18, 2012 at 9:45pm more of my latest videos here (different platforms as well):
http://www.zminteractive.com/portfolio/aerial-videos-and-photography/
Comment by Franco Scipioni on August 20, 2012 at 2:06am I wonder what effect of changing the current prop spin configuration to having each arm dedicated to one direction (upper and lower props moving same direction) and alternating spin directions with each arm would have on your yaw issues. I imagine that this could limit environmental factors (such as wind) on gyroscopic-dependent yaw effects because it won't matter if the upper and lower props spin at different velocities.
Comment by Ziv Marom on August 22, 2012 at 10:52am Franco - to your question, I think the wind from the top motors will effect too much on the bottom props.. they will have to spin double fast to have a strong push,,.
Here is another video we did, same place with the CineStar8
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1288 members
125 members
39 members
4 members
24 members
Powered by
