I've now had a chance to see and test virtually all the EasyStar clones out there, so this post will compare them all and make recommendations. There are a few others out there by different names, but I think most are just rebadged versions of the ones below. Bottom line: I think the HobbyKing Bixler (see below) is the best option.
First, the baseline: The classic Multiplex EasyStar ($72 for basic airframe, no electronics)
Pro: Lots of cockpit room, tough, flies well.
Con: Only 3 channels, comes with terrible brushed motor that must be upgraded, rudder too small and must be enlarged. Quite expensive once you add all the stuff you need. See our post on upgrading it here.
It's available as a kit, a RTF with a 4 channel radio, and an ARF without radio. I recommend the ARF version, which is just $52. Add a 20a ESC, battery and charger and 7ch RC radio and ArdupilotMega and you've got a UAV for under $500.
Some of the advantages of the Bixler, compared to the EasyStar and the other clones:
This is a comparison the Bixler cockpit (left) with the EasyStar (right). The Bixler has a bit more room.
Dynam HawkSky ($99 with everything you need: servos, brushless motor, LiPo and charger). See our review here.
Pro: As much interior room as the EasyStar, has ailerons, comes ready to fly.
Con: Plastic motor pylon is noisy. Included FM RC system should be thrown away and replaced with proper 7+ channel digital radio.
Xen Phoenix ($48 for airframe with brushless motor. Servos etc not included). See our review here.
Pro: Brushless motor and ailerons
Con: Fuselage is too narrow. Not enough room for autopilot electronics. Fragile. Weird four-bladed prop.
Sky Surfer ($130 with everything you need: servos , brushless motor, LiPo and charger, 2.4 RC system)
Pro: Comes with digital RC system (only 4ch, however, so must be replaced for UAV use). Solid design w/ailerons
Con: Sadly, the design has changed and what appears in the product listing to be servos on the outside of the body, like the EasyStar and HawkSky, are now on the inside, taking up valuable interior room. Here's a picture of what the current cockpit is actually like:
AXN Floater ($50 with servos and brushless motor). Formerly known as the Cloud Sky
Pro: Inexpensive, solid design w/ailerons
Con: servos on inside of cockpit like SkySurfer, robbing interior of valuable room for electronics. Narrow nose makes 2200 LiPo a tight fit.
Comment by Rana on January 15, 2011 at 7:08pm Very nice work ! will be very usefull to all !
For those that might decide to give the AXN Floater a try here is my build log.
Comment by Hamish on January 17, 2011 at 12:48pm " 4-blade propeller provides more powerful and stable performance"
are they having a laugh !?!? the less blades, the better folks. Big aircraft have lots because there ain't room for a giant 2 blade
Comment by CrashingDutchman on January 17, 2011 at 2:26pm i have the hawksky .. awesome ..
Comment by jordan stocker on June 16, 2011 at 9:20am would this work http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=... Lol
Comment by robomotic on July 13, 2011 at 11:06am Robomotic, did you read comments concerning this plane? I am not sure you need it...
Comment by James on October 12, 2011 at 9:19am Just killed my AXN Floater.
Alas, no amount of carbon fibre reinforcing, hot glue, epoxy and duct tape will get it back in the air after that last crash.
It is a good training airframe though, but I am not sure it would be the easiest plane to mount the APM in. Fuselage space is very limited unless you are willing to do some serious cutting.
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.32 members
18 members
32 members
109 members
22 members
© 2012 Created by Chris Anderson.
