My goal for part 2 of the video is to have the RQ-11 Kit fully assembled and operating as an ROA (Remotely Operated Aircraft). My overall goal though is to buy a autopilot from diydrones and make it into a fully functioning UAV. I want to use it for agricultural and animal tracking purposes. Learning programming through my college classes I want to create a fully functioning UAV that has a flight time of around an hour or more that could be used to track animals and photograph agriculture.
Things to do:
Suggestions Welcome!
Don't mount the camera until you have flown it and know it.
Comment by Tom on December 22, 2012 at 7:27am Having owned that RQ-11 clone, my honest advice would be to get a different airframe if you want to add weight to it. If that's not possible, you should look at strengthening the joints between the three wing pieces and the mounting points where the wing attaches to the fuse. Not sure exactly how much extra weight mine was carrying when the wing folded, but it was only in the region of 200g (in addition to the electronics and a 3S 2700Mah battery).
It's a good looking model, in a utilitarian kinda way (certainly must be the only 1:1 scale military model you can buy) but it's not a load carrier, despite its looks and the roomy fuse.
My experience is way different than that of Tom.
I believe this to be a great platform, but you MUST reinforce certain areas and follow the recommendations regarding servo throws. I stuffed a 5000mah 3 cell lipo into mine and a friend flies with a 4500 mah 4 cell lipo. I'll put some more details on prop and stuff on my own page, but for now here's some of my blog.
I got everything now but the prop. What size prop should I use for the Projet RQ-11?
I put on a 8x6E pusher. I'm making the part 2 video and blog tonight on my progress on the RQ-11.
Comment by Ricardo Affonso on January 7, 2013 at 6:26pm you don't need the prop to be pusher...just mount it to the front and swap 2 motor wires, the motor will turn on the reverse and the prop will be ok!
(@Ricardo Affonso) Thanks for the tip on getting the motor shaft to spin reverse I was having that exact problem!! Switching two wires around worked perfect no problems. I will make sure to add that tip to video part 3 of my project series.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
51 members
185 members
134 members
24 members
Powered by
