Runcam Split hd Camera Review
Runcam is as known by its hd fpv camera with high quality. Many pilots have tested Runcam other versions (Eagle) before they released the new amazing split one. Lucky, I have received it and want to share this Runcam Split Camera Review on here, please go ahead if you are interest in it.
What you get?
  • 1x RUNCAM SPLIT CAMERA
  • 1x WiFi module
  • 1x 180mm Lens Extension Cable
  • 1x Aluminum bracket
  • 1x ABS bracket
  • 1x 3pin FPV silicone cable
  • 1x TV-out and power cable
  • 2x Set of screws
  • 1x Manual
About $90 you can get it, very light only 21g. Improved Sd card Mount.
No more push mechanism like Runcam3 or Session5 . to prevent accidental removal . they are now using latch design now no more accidental popup’s. for more protection use electrical tape. by mounting on your FC you can’t remove your Sd-Card anyways we can use Micro-Usb for file transfer.
Too long, More details for setting and feature, please go to the original place http://www.rcdronegood.com/runcam-split-camera-review/
