I was working on getting the SITL simulation up and running this weekend, and was able to modify MAVProxy.py to support real-time control via a joystick or gamepad, here is the updated file:
It requires installation of pygame (http://www.pygame.org) It will probably require some modification to map the axes on your particular controller to the proper APM channels, in these lines:
cmd_rc(["1", str(int(j.get_axis(2)*400 + 1500))])
cmd_rc(["2", str(int(j.get_axis(3)*400 + 1500))])
cmd_rc(["3", str(int(-j.get_axis(1)*800 + 1100))]) #throttle
cmd_rc(["4", str(int(j.get_axis(0)*400 + 1500))])
pygame prints any control input changes to the terminal, which can be annoying because it scrolls away some of the normal mavproxy messages.
I tested it flying the ArduCopter, and it works well, hopefully it will be useful for testing modifications to manual control modes.
Update:
I created a mavproxy module file that can be loaded into the normal version of mavproxy.py:
Copy this file into the /modules folder, and from within mavproxy, load the module by entering:
module load joystick
Axis mapping is still custom to the Logitech Dual Action, so modifications may be required for other devices. One issue is that it still writes the state of the joystick axes to the console - I'm still looking into whether there is a way to suppress this.
For future work, I want to add support for some of the gamepad buttons to change rc channels 5-8 to be used for changing mode, dropping waypoints, etc,
Andrew
Great work Andrew!
If you want it to accepted into the mainline code, I'd prefer it was re-done as a mavproxy module. Then you would do "module load joystick" to get joystick support. You can put that in a mavinit.scr file if you like or use --cmd to run it every time.
Where possible I'm trying to keep new features like this as modules. That will hopefully prevent the main code from getting too unwieldy. I'll probably also move some existing features into modules over time.
If you look in the modules directory in MAVProxy you'll see there are currently 3 modules:
The drop module demonstrates how to control RC channels, which is what the joystick module would need to do.
There is no documentation on the module API I'm afraid, but basically anything that can be done in MAVProxy can be done in a module. Sometimes its handy to export a core mavproxy function into mpstate.functions to make a module easier to write.
Do you want to have a go at redoing the joystick support as a module? You'd then become the maintainer of that module in the future.
Cheers, Tridge
another tip. When developing a module, its useful to do "set moddebug 1". That will allow you to see exceptions that happen in modules.
Comment by AndrewF on April 2, 2012 at 7:59pm Sure, I'll try to set it up as a module, I'll need to learn a little more about how the modules work, but that should be doable. Thanks for the feedback!
Thanks for the update Andrew! I've added it as a standard module in MAVProxy.
The only small change I made was to check for mpstate.status.exit, otherwise the thread hangs around when you control-C mavproxy.
Thanks for a great contribution!
Cheers, Tridge
Comment by The Captain on April 13, 2012 at 9:40am Hi! This is my first post. I've been lurking the forums off and on for a few years, but have not had the resources to even consider a build until now.
I was wondering if anyone had tried to use an xbox 360 controller to control either a simulation or an actual drone. I think I remember seeing something about US drone pilots using those controllers, I can try to find the article and link it here.
I think it would be a cool idea due to controller's great familiarity for a large number of people, the relatively low cost and high availability of the controller, and the proven reliability from countless long hours of gaming.
I'm not sure if doing this would require you to interface with a computer or if there is a way to wire it straight into the board.
Anyhow, hello.
Comment by The Captain on April 13, 2012 at 10:25am Oh, and here's the link I referenced with the US military using xbox controllers to pilot drones:
http://www.gamepolitics.com/2008/07/20/military-using-game-controll...
Comment by Antonio on September 25, 2012 at 8:47am Hello,
with this module i can control the Arducopter using a Joystick? I ask this because i don´t have joystick to try it and i have to buy one.
Thanks!
Comment by AndrewF on September 25, 2012 at 6:05pm This module is only for controlling the SITL simulation with a joystick, not the actual ArduCopter.
Here is documentation on flying the actual ArduCopter with a joystick, via the Mission Planner: http://code.google.com/p/arducopter/wiki/Joystick
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.688 members
185 members
24 members
51 members
1295 members
Powered by
