I set up three 3k circles around my field to test range and how the Raptor would perform during an actual travel environment, and it performed very, very well. A perfect flight. You may see at the end I realize that my RTL altitude was set to zero, but luckily I was quick enough to set a guided mode until I could manually return it home.
Awesome stuff! Thank you DIYD!
Hi Trent. Great show! Two days ago I just had my maiden flight with arduplane. Yesterday I got already RTL and waypoint navigation working. Your show helped me really a lot. You propable although saved me from a few crashes and many frustrated hours.
You can set the RTL altitude in mission planner in the advanced parameters list. The parameter is ALT_HOLD_RTL. The default value should be 10000 (100 meters).
Hi Trent really love the shows. Are you still updating www.mygeekshow.com as the last episode showing is episode 118 and I see this one is 123
