100KM
Techwing: an openFoam case study
Hey everyone!
 I am really getting a handle on openFoam. I have figured out the scale and mesh resolution problems I have been having. I can now produce highly detailed data sets of the air flowing over the current techwing design.
tip-vortex.jpg?w=900
this is the airflow over the wing tip. Needs improvement.
tip-vortex3.jpg?w=900
here is another look from the side the surface is colored with the local pressure numbers. red is highest blue is lowest
negative_p_points.jpg?w=900
This is a view showing the negative pressure contours, represented by colored points.
pillowofair.jpg?w=900This shows the positive pressure contours.
Now I can make some minor changes to the geometry and see exactly how it will effect performance and flyabilty. Check hobbyuav.com for the latest techwing news.
  • Rick, a flying wing offers benefits like reduced wetted area and trim drag and is more structurally efficient, but this aside, it has the same constraints as a conventional layout.  Where it suffers is the size of its lift envelope, which can easily destroy any advantage it begins with.  The CL_max is pretty much done at 0.7-ish, because increased reflex to give you the required pitching moment reduces the CL.  For a conventional layout can see CL_max as high as 1.2 or even beyond.  If landing speed is a key design criteria, then the wing area required for a flying wing is 1.2/0.7-times as great, and since wing area is drag, this has a large impact on cruise and high-speed capability.
  • 100KM
    Thanks andrew. I am 6'7" so should be able to see pretty far. Lol. The motorbike tutorial solves in a few minutes. The techwing case has around 800,000 and solves in about 3 hours running on a single core on a AMD fx-8150 3.6 ghz.
    You can descretize the mesh and run it multi threaded too. It takes a little more set up.
  • BTW, how long does a solution take, how many elements and what sort of machinery are you using?
  • Nice work Wayne!  I need to stand on your shoulders for a minute and take a look into the future! :)
  • 100KM
    No, the techwing is an original design. It has a 35 inch wing span.
  • 100KM
    Sure, I can post some step by step instructions.
  • Really nice Wayne,
    Maybe you could post some tips on using openFoam or put something on your site.
    Best Regards,
    Gary
  • 100KM
    here is the techwing @ 20 degrees alpha
    3701725811?profile=original
