I have finished my Arduino based pulse width modulated (PWM) hot wire cutter controller. It allows precise USB or analog temperature control of a hot wire of length from 10cm to 2m for use with manual cutters or CNC based cutter. The PSU is extermal (battery or PSU) The 12v power is attached to the GND and + 12V terminals. The + to the hotwire is attached on the red terminal on the top. The current return thru the FET is connected to the black return terminal. An FTDI board can be attached to the Arduino thru the "programming window".
What do you think :) ?
Comment by L-P Lorentzen on July 10, 2010 at 2:18pm
Comment by UFO-MAN on July 10, 2010 at 2:20pm
Comment by brakar on July 10, 2010 at 3:28pm
Comment by UFO-MAN on July 10, 2010 at 3:48pm
Comment by Jeshua Lacock on July 10, 2010 at 11:12pm
Comment by UFO-MAN on July 11, 2010 at 3:53am
Comment by UFO-MAN on July 11, 2010 at 4:03am
Comment by UFO-MAN on July 11, 2010 at 4:16am
Comment by Brendin on January 11, 2011 at 2:45pm Hi,
Nice work. Is this the most current schematic? I thought I read that you used two fets in parallel. Anyhow if you can share another pic of the updated schematic I will create the eagle schematic and do a board layout. I'll create the board on my CNC router. (I'll send you the eagle files) I've got some atmega 48P's kicking around here I can use.
I am starting my CNC foam cutter build and would like to use this for the hot wire. It would be cool to include automatic temperature adjustment and on/off.
thanks!
Comment by UFO-MAN on January 11, 2011 at 2:53pm Hi Brendin! Thanks for commenting. An Eagle Layout would be nice. However be careful when milling fiberglass substrate. Dont breathe the particles from a milling operation as they are bad for your lungs.
What I did in the last version was to actually replace the one FET with two in paralell. I just "piggybacked" one fet on top of the other (pin for pin). If you find a FET that can handle more current you probably only need one. The driver chip (EL7212) does have more than one output so you can use two outputs. Then you need to wire the pwm signal from the uC separately to two EL7212 inputs and then those outputs will need to be routed to the gates of each fet. I am not even sure you need the driver chip. An emitter follower and a resistor to ground probably would do the job. The reason EL7212 chips are used is that the gate input has some capacitance. This can reduce the swithcing speed. But in this application the switching speed is low so it is hardly a problem. I reused a circuit I used to experiment with ultrasound some time ago.
720 members
203 members
1355 members
207 members
Powered by
