Although we recommend the uBlox GPS module and adapter we sell in the DIY Drones store, which is solid and easy to set up, ArduPilot can support any GPS module in NMEA mode. The tricky bit, however, is usually the connector and programming it to the right baud rate and other settings. Although every GPS module is different, here's a tutorial for two common ones that may help you with others.
Comment by Daniel Gru on April 26, 2010 at 2:11am
Comment by Tim - Arduino for Visual Studio on April 27, 2010 at 5:36am
Comment by Ludovico Antonio on April 27, 2010 at 10:47am
Comment by michael dunston on December 10, 2010 at 7:05pm i broke the gps plug on the arupilot can i plug it to the other gps 4 pin input? if yes how?
Comment by Tim - Arduino for Visual Studio on December 11, 2010 at 5:28am there will be 4 pin holes immediately behind the plug that you can use instead?
Comment by michael dunston on December 11, 2010 at 7:26pm yes i see them but what cable go where exactly.. ?>
how can i connect the gps to it.
Comment by Tim - Arduino for Visual Studio on December 12, 2010 at 6:10am I think the pins match the original cable order. so you can either solder pins into the holes and then solder the gps cable wire to the pins or you can solder the cable directly to the pin holes.
or you can buy the ublox adapter from diyD store which I think gives a set of matching pins and an alternative socket
Comment by Richard Warrender on July 1, 2011 at 10:21am Sorry to drag up an old post but isn't the Locosys 20031 a 3.3v GPS? I thought the ArduPilot gave out 5v on the GPS pins? I don't want to fry the GPS.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.8 members
182 members
15 members
50 members
247 members
Powered by
