HackEDA (previously) has improved it's software algorithm and is now running a Kickstarter campaign that offers the ability to instantly create pcb designs, and even manufacture boards by dragging and dropping chips in your browser.
Project page on Kickstarter.
Thanks. That's pretty much how I do it today. I print eagle traces to a postscript file and then outline the traces in a vector graphics program. Works most of the time, but you have to be careful with trace separation in tight spaces.
A nice thing about this is that you only remove copper around the traces, so you automatically get a nice ground plate as a result. :)
Thanks John!
It's also meant to be a good way to start a project and get the annoying parts out of the way quickly.
Outlines aren't supported directly, but looks like there are a few solutions out there (none of which I've verified). Assuming your equipment can handle the trace widths, and you love dealing with vias, these options are intended to take gerbers and output DXF:
Very nice. I'm a bit past this stage when it comes to PCB design, but backed anyways to support a good idea.
One question. Can it generate "outline" traces so that you can make PCB's using a CNC or laser engraver?
