Using ArduPilot 2.x in the field
Instructions for using ArduPilot 2.x in the field:
ArduPilot 2.1 and above (with Z sensor). This version of the software auto-calibrates the IR sensors. The only thing you need to do at the field is to record the "home" GPS position in EEPROM memory, which will not be erased when you reset or power down the board. To do so, follow these instructions:
  1. Ensure that the autopilot is in manual mode (channel five toggle off) and GPS is connected
  2. Place a jumper cap on pins D6 and D7 (you can also connect a regular RC power switch to those pins if you want to control the autopilot from outside of the aircraft). Ensure that your aileron and elevator sticks are in the center position, and power on the board.
  3. The yellow status LED will blink for a few seconds as the autopilot programs the GPS for binary mode. Then the blue lock GPS will blink rapidly, which means the autopilot is waiting for GPS lock. You can now remove the jumper (or return the switch to the normal position)
  4. When the autopilot has established a GPS lock it will move the rudder. Note that ArduPilot puts the EM406 into binary mode, which disables the red LED on that module, so it will not blink.
  5. You’re now ready to fly! Press the reset button on the ArduPilot board to restart it (your calibration settings are saved in permanent memory and will not be erased).
  6. ArduPilot 2.0 supports two autonomous modes: waypoint and return-to-launch (RTL). If you have a three-position toggle switch or a proportional dial on your RC transmitter, the middle position is Waypoint Mode and the up (or full clockwise) position is RTL Mode. These can be changed in the software if desired. The Mode LED on the ArduPilot board will light up with it is in Waypoint Mode.
  7. To use fly-by-wire mode (just stabilization, like the FMA Co-Pilot), simply disconnect the GPS. ArduPilot also automatically switches into stabilazation mode if it ever loses GPS lock.
ArduPilot 2.0 (no Z sensor): This version requires that the IR sensor be calibrated in the field, on arriving and if the weather conditions change significantly:
  5. Holding the aircraft without obscuring the thermopile sensor, point the nose at the ground. Switch the autopilot on with your RC toggle switch. The elevator will move, signaling that the sensor has been calibrated.
  6. You’re now ready to fly! Switch the aircraft back into manual mode for launch, and press the reset button on the ArduPilot board to restart it (your calibration settings are saved in permanent memory and will not be erased).
  7. ArduPilot 2.0 supports two autonomous modes: waypoint and return-to-launch (RTL). If you have a three-position toggle switch or a proportional dial on your RC transmitter, the middle position is Waypoint Mode and the up (or full clockwise) position is RTL Mode. These can be changed in the software if desired. The Mode LED on the ArduPilot board will light up with it is in Waypoint Mode.
  8. To use fly-by-wire mode (just stabilization, like the FMA Co-Pilot), simply disconnect the GPS. ArduPilot also automatically switches into stabilazation mode if it ever loses GPS lock.
  • Hello Folks !
    Above instructions in two page large font PDF document, what I suggest to take print and handy in the field;
    I have extesively tested ArduPilot 1.0 & 2.0 and found it is matchless and simply great autopilot in just 25US$.
    Instructions for using ArduPilot 2.x in the field.pdf
    https://storage.ning.com/topology/rest/1.0/file/get/3691995330?profile=original
  • No body in the world can beat Ardupilot on its price vs. functionality.
    Nice write up as quick instructions in the flying field.
    Marco, that's totally weird. I suspect a soldering problem with your board--maybe the interface forces some pins out of a short situation?
    If you're using the 2.4 code, you need to ensure that the configuration file is set for the right GPS module. I don't see why being in Italy should be a problem; we have plenty of users in Southern Europe (I can't remember any particular ones in Italy, but I'm sure there are some).
    You might want to check the GPS modules with Sirfdemo, which will at least tell you if they're getting a lock.
    I'm afraid 2.1 is long gone and no longer supported; I can't even remember how that software worked. If you can get a shield, you can stay up to date with the latest software and we can support you.
    If connector does not seat all the way, slightly up on one side, a pin is probably bent.
    I had problem with two connectors, pin 1, and pin 6 bending over.
    I just straitened them out with fine tweezers. and made sure hole was open on plug.
    Use good light and a magnifier to check connector as these pins are very small...
    Yes, that means that there's something wrong with the GPS communications. Check the pins in the EM406 connector on ArduPilot. Is one on them bent?
    If it's possibly for you to get a shield, I think you'll have a much better experience with ArduPilot. We don't support the code you're using anymore and the new code is MUCH better.
    LazyPilot: we're going to be issuing a release version of 2.2 on Friday, with a full instruction manual. Can you wait till then and use that code and instructions?
    LazyPilot: I need more info. Are you doing the field setup procedure with the jumper? Resetting afterwards? Using the EM406? Getting lock? Toggle to RTL position?
  • Chris,
    I'm using the 2.2 software. Pressing the reset button didn't change any LED behavior.
