VBrain (MP32F4 v4) is available we finish the test on Arducopter32 rev 2.7 at it work fine Great Work DEV TEAM :)
Dear Friends,
after 2 month of test I'm happy to inform you that the VBrain is ready to fly.
The platform is a result of 4 years of work on ARM autopilot platform. It's last evolution of Multipilot32 platform. I'm very happy that this is the year of ARM and we are here to present our last creation : Simple , Smaller and Ready to Use.
VBrain is a good choose for OEM ready to use hardware platform.
The VBrainautopilot features include:
  • 168Mhz ARM CortexM4F microcontroller with DSP and floating-point hardware acceleration.
  • 1024KiB of flash memory, 192KiB of RAM.
  • MEMS accelerometer and gyro, magnetometer and barometric pressure sensor.
  • 8 RC Input standard PPM , PPMSUM , SBUS
  • 8 RC Output at 490 hz
  • 1 integrated high speed data flash for logging data
  • 1 Can bus 2 i2c Bus
  • 3 Serial port available one for GPS 1 for serial option 1 for serial telemetry.
  • 3 digital switch (ULN2003).
  • Jtag support for onboard realtime debugger.
  • 1 Buzzer output.
  • 1 Input for control lipo voltage
  • Include in the standard Vbrain Package there is VBrain GPS module , the module support MTEK 3329 gps , Ublox module , Fastrak IT600. On the module is available optional magnetometer. You can disconnect the board and put it far from brushless motoros to solve the problem of noise on mag signal.
  • Physical Dimension 6x4 cm
  • Will be available a case
It's first Universal Arm hardware platform . On it is available different kind of firmware : Open or Closed source . The main firmware available is Arducopter32 , last revision is 2.7 In the next day will be available a full fly test.
This platform is fully compatible with different kind of RTOS : FreeRtos , ChibiOS , Nuttx , CooxOS .
Our first target when start to develop our hardware platform 2 years ago was to develop a simple and powerfull ide.
We develop VRIDE PRO that is a special distribution customize by FoxTeam and LaserLab guys. The Ide use Eclipse as Editor, GCC as compiler , GDB and OpenOcd as Debugger.
This is the link of ready to use Ide:
http://code.google.com/p/multipilot32/downloads/detail?name=vroboti...
The ide support different kind of workspace and library. Our first target was porting all arduino and APM api to ARM platform.
The supported firmware are Arducopter32the last revision available is 2.7 the status of firmware is ready to fly .
The Workspace with last revision of code is available here :
http://code.google.com/p/multipilot32/downloads/detail?name=ACopter...
Our Team are working also on PX4 enviroment , first target was to port Arducopter32 on PX4 and PX4 enviroment to Vbrain and MP32Fx platform.
The hardware is compatible also with other opensource firmware as AutoQuad AeroQuad and OpenPilot. A lot of work are doing on IDE and firmware to share it on our platform.
We try to work to a new Opensource Standard based on high performances STM32F4 micro controller.
The price for VBRAIN with GPS Board (MTEK 3329 rev) developer revision is 199 euro.
It's also available a ready to use board with 3 days of support by team viewer at 270 euro.
There is also available a oem version of product.
We are Ready for pre order the first batch of production will be available in 3 weeks some sample is yet available.
For more info about VBrain : http://www.virtualrobotix.com/profiles/blogs/vbrain-coming
or contact virtualrobotix@gmail.com
Best
Roberto
Comment by Jack Crossfire on July 27, 2012 at 1:37am
The STM32 is the new atmega.  It is a lot easier to get working than the previous ARMs.
Comment by Roberto Navoni on July 27, 2012 at 2:59am
Hi Jack,
yet STM32 is the new standard for Autopilot Opensource Board and also a lot of closed source platform is based on that micro controller.
So in Italy i decide to start the certification process of a Drone for professional and Civil application . So my idea  is to have two platform one for hobby and other for professional app , but with the same core.
Best
Roberto
Comment by emile on July 27, 2012 at 8:29am
Great news Roberto. As always a volcano odf ideas!
Comment by Roberto Navoni on July 27, 2012 at 9:09am
:) Today I'm testing the new VR IDE PRO . The new name will be VR Universal IDE :)
Inside the workspace is available the source of AutoQuad , Arducopter32 and PX4 .
So one Ide 3 Project ready to use for your STM32F4 universal Autopilot platform .
At the moment it's available "only" the Windows 32-64 eclipse revision of IDE.
I know that other Developer working on other Opensource platform : Openpilot and AeroQuad32 ,too
Comment
