MR60
Review and tests of anti-vibration systems
3689621538?profile=original
To optimize videophotography results, vibrations need to be reduced as much as possible. The objective is to disturb as little as possible a brushless gimbal holding a camera. (we all know too well how hard it is to get a brushless gimbal well tuned).
As most people, brushless gimbal tuning is done on the bench using accelerometers & gyros of the brushless gimbal's IMU. And like most, we do not get as good results when flying. Why?: frame & air vibrations. Frame vibrations are created by motors, props and wind. Direct air vibrations (external wind) also impact the brushless gimbal.
This is a blog post showing anti-vibrations objective measurements of different isolation systems, obtained on my Mr. Grey X8 workhorse shown on the introductory picture. All vibrations measurements are made during periods of min 30 sec of hover in stabilize mode. Take-off and landing periods are excluded of measurements.
Configuration of the test craft:
-Pixhawk controlled -Stabilize mode
-T-Motors MT3515-400Kv
-15x5 XOAR props
-6S batteries
-2 axis brushless gimbal - Alexmos
-Sony NEX5 camera
-Weight of the gimbal+camera+fpv+3S 1ah battery : about 1250 g
-AUW : about 6.8Kg
Vibrations measurement setup:
-All tests were made with the craft configured fully ready-to-film : except the gimbal which remained off not to measure its own generated vibrations. The camera was thus simply screwed on the gimbal with no power to the brushless motors.
-X-Cam vibration measurement tester
3689621615?profile=originalX-Cam is installed on the different areas of the craft to be tested. Its mesaurements are triggered remotely by a PWM pulse (on/off switch allocated on Taranis). It is powered directly through the PWM servo cable connected on the receiver.
Data are stored on board its flash memory. It is made for vibrations measurements in the 0-200Hz range and can store up to 3 min of continuous measurements.
Through the X-Cam GUI , data is downloaded from the flash memory to produce a time graph (basically useless as it shows the X-Y-Z vibrations measurements along the time axis), and a frequency graph showing X,Y,Z vibrations amplitudes (in number of g) versus frequency (in Hz). Raw data or weighted averaged data can be calculated.
Two anti-vibration systems were measured,
First a silicon ring system as shown below,
3689621626?profile=originalFour of these were used in a X configuration between Mr Grey's two plates (see introductory picture). Each plate is made of plywood; square shaped with 20 cm long sides.
Silicon rings come in two stiffnesses: red for softter silicon, black for stiffer silicon. Here, only the red softer ones were tested. Each Secraft system costs about 9 euros each (www.secraft.net) , which is relatively cheap.
Second tested system is a "Bell" shaped  precompressed silicon system. Each "Bell" is made for a 250g payload. Each one of them costs about 39 euros (www.altigator.com) which is quite expensive. It is mostly used in high end professional aerial photography rigs :
3689621639?profile=original
Four of those were used, in each corner in between Mr Grey's test plates as shown below:
3689621709?profile=original
Reference measurement:
In order to compare results, a reference measurement is made on the frame itself, with the X-Cam placed at the center of Mr Grey's top plate, under its protective "flower pot".
3689621802?profile=originalFrequency domain picture shows two frequencies were vibrations are significant : 85Hz and 175Hz; The measurements show about 0,3g of vibrations on all three axis at 85Hz; and 0,4-0,5 g vibrations at 175Hz.
First test result with Silicon rings system:
X-Cam is now placed on the second bottom plywood plate on which the gimbal is fixed,
3689621820?profile=originalThe results show that frame vibrations are continuing to pass through to the gimbal at the same frequencies (85Hz and 175 Hz) but amplitudes are divided by a factor of 10 at 85 Hz and almost by a factor of 20 at 175Hz, versus non damped frame vibrations.
Second test with the "Bell" system:
X-Cam is placed at the exact same location as for the first test,
3689621720?profile=originalThe results show that frame vibrations are continuing to pass through to the gimbal at the same frequencies (85Hz and 175 Hz) but amplitudes are divided by a factor of 2 at 85 Hz and by a factor of about 2 at 175Hz, versus non damped frame vibrations.
If we show the silicon ring's system on a graph at the same scale as Bell's system:
3689621754?profile=originalThe silicon ring anti-vibes system literally erase vibrations in comparison with the "Bell" anti-vibe system....
Comparison of both anti-vibrations systems:
It appears clearly that the "silicon ring system" is much more efficient at reducing vibrations versus the "Bell" system. Further, this silicon ring system is much cheaper than the Bell system.
For once, more expensive, supposedly professionnal parts were not up to the task verus cheaper diy parts.
Cheers,
Hugues
  • Hi Hughes, and Gary.
    As you know i have been a fan of silicone rings for a while now and blogged the development of my quads and octa. I have been using them successfully now for almost 2 years.
    Here are a couple of pics of the way im using them.
    3701865407?profile=original3701865386?profile=original3692632092?profile=original3701865461?profile=original
  • MR60
    Thx Philip.
    Actually we should be able to use the IMUs we have for gimbals (i have a few laying around) to make the gyro measurements you are talking about, with a piece of arduino code. Any dev volunteering to develop this ?
  •   Good job with the testing!  It's nice to see a well executed experiment accompanied by a solid write-up.
     I would like to see this type of testing where both acceleration and angular rate are recorded simultaneously.  I think a lot of people get fixated on acceleration, while in my opinion angular rate is what really causes the most significant image distortion in optical devices.  Acceleration might be a good indicator of angular rate, but given how easy it is to gather angular rate, I'm interested to see how they compare.
      Side note: The scale of the "amp (g)" axis on the final graph ("Silicone rings damper (same scale)") is too large by an order of magnitude.  The maximum axis value shown is 3,2 while the maximum value of the Bell damper graph is 0,3.  The silicone ring damper is definitely better, but not quite a significant as that graph makes it look.
  • MR60
    very clean build. How many of these dampers do you use , 4 or 6 ? What are the dimension of these blue dampers ?
    The secraft dimensions are :
    3701856850?profile=original
    https://storage.ning.com/topology/rest/1.0/file/get/3701856850?profile=original
  • MR60
    Hi Gil, these you bought are indeed very similar to the tested ones. However you have there a system with a single orientation of the o-rings, while the tested system uses two perpendicular sets of rings which improves the mechanical stability.
    Thx for posting these various o-rings possibilities, I will take a look at it.
  • Hi Hugues,
    I developed the suspended O-ring platform before I knew about Zeal and have always found it to yield good results, and in fact, the first results we ever had that consistantly got our vibrations down into the "satisfactory" sub 0.3G range.
    In fact I have made dual platform autopilot supports using both O-rings and Zeal which had a small improvement over either one alone but they both work fine.
    On the Flip FPV Pro, the presence of the vertical standoffs in the right ;location on the "floating" frame made it too tempting to ignore the possibility of easily using O-rings.
    My honest estimate is that Zeal would work about the same, so it is a simple choice.
    The O-ring supports do make it a lot easier to remove the Pixhawk from the frame than Zeal would though, you can just pop the O-rings off the top of the extended case screws.
    Oliver and I have optimized ours for larger props and high efficiency KDE motors, but the standard arms, are in fact designed for 10" props and it flies very well with those.
    http://www.hoverthings.com/frame-sets/flip-fpv-pro-g-black-gimbal-v...
    Even with 10" props you could carry quite a bit more weight, with even average motors, it hovers at less than 50% throttle with a GoPro and gimbal.
    If you really want to carry big payloads or get longer flight times you might be better going with the extended arms and bigger props, they really do make a considerable difference in efficiency and flight time especially (heavy).
    I am very fond of this frame and consider it one of the most practical "kit" frames you can get, it is extremely rugged and well laid out for what you need it to do.
    It flies very well and because of it's small side profile is very stable even in gusty winds.
    I do like the 3D printed vibration isolation frame which, interestingly is a variation on one I saw a couple years ago that used the same O-ring support method I now often use and which I borrowed from them.
    The O-ring support method does require a bit of tuning playing with O-ring diameters and the diameter of the oring tubing itself.
    Also, Silicone O-rings work a bit better because they have better intrinsic damping then Buna-N.
    Our vibration control is always a trade off between elastic (spring) and true damped (shock absorber) methods.
    Generally the materials we use incorporate both characteristics, but currently our quantitative appreciation of these is sorely lacking, your Blog here is a great start in the right direction.
    Best Regards,
    Gary
  • MR60
    Clever way to mount the o-ring , Gary.
    Why did you choose for this method instead of simply putting he pixhawk case down onto the bottom plate ? (with Kyosho zeal for ex or a suspended mount I like very luch such as this one : http://diydrones.com/profiles/blogs/3d-printed-anti-vibration-mount)
    I like this FPV pro frame. What would be the maximum payload you could fly with , considering 10" props and 3S batteries on this frame ?
  • Hi Hugues,
    All I did was use longer small machine screws in each corner with a nut threaded down to actually secure the top of the case and leaving about a 1/8" gap between the top of the nut and the bottom of the machine screw head.
    This is not quite ideal because the threads on the machine screw can cut in to the Oring and eventually cause it to fail. (Oliver has had one fail in this way already).
    A 1/8" piece of small heat shrink on the machine screw under the head should solve this problem.
    On mine, 2 different size O-rings are used because the front frame standoffs are further apart than the 2 standoffs nearer the middle of the floating frame.
    On mine I have also put in a tightly cinched ziptie on each of the standoffs which I position just under each )-ring to keep it from vibrating down the standoff.
    And mP1, Kyosho Zeal is great stuff and well damped, it really wouldn't work for damping the entire floating frame in this case because the dimensions are wrong, but using a 1/2" to 3/4" square of it under each  corner of the flight controller is how all my  other PX4's and APM's are supported.
    I actually wrote the Wiki page on vibration where I strongly extol the virtues of Kyosho Zeal.
    http://copter.ardupilot.com/wiki/vibration-damping/#Gel_pads
    (Thats my PX4 Flamewheel in the pictures with the 4 Zeal pads).
    This high mass (battery) suspended intermediate frame is a different thing though and it demanded a different solution.
    Sorbothane is cool stuff too.
    Best Regards,
    Gary
  • Hi Hugues,
    A 1/8" piece of small heat shrink on the machine screw under the head should love this problem.
    On mine, 2 different size orings are used because the front frame standoffs are further apart than the 2 standoffs nearer the middle of the floating frame.
    Best Regards,
    Gary
  • MR60
    Thx for posting your details. This is a quite remarkable anti vibration combination. In particular the o-ring suspended pixhawk. Can you please post a better detailed view how the o-rings are fixed to the pixhawk case?
