Thanks to Pteryx for this great data set! In order to generate a geo-referenced NDVI / EVI / EVI2 Vegetation Index we need to fly the area of interest (AOI) with a visible (RGB) and full spectrum (RGB+NIR) camera. Once the RGB and RGB+NIR images are processed inside DroneMapper we have two orthomosaic results from which we can generate a pure NIR ortho. To do this, we use GDAL and the following command:
/usr/local/bin/gdal_calc.py -A VIS.tif -B NIRVIS.tif --outfile=nir.tif --calc="(A - B)"
Now that we have created our pure NIR orthomosaic we can use this to generate NDVI or other calculations using OTB in an automated fashion.
/usr/local/bin/otbcli_BandMath -il NIR.tif VIS.tif -out ndvi.tif -exp "ndvi(im2b1, im1b1)"
In order to process the orthomosaic tif files, they need to be the exact same size and pixel resolution. OTB also has many other useful commands for remote sensing work. The original flight and area of interest is 1.0 km sq @ 10 cm GSD.
Thanks -- JP @ DroneMapper
Comment by FlyingMerf on February 10, 2013 at 4:48pm Nicely done! Dronemapper does a great job on the image processing.
A simpler, arguably comparable method to create NDVI data is to use an "NDVI" converted camera from MaxMax.com, and calculate a blue NDVI. The converted camera senses blue, green, and NIR. The blue is substituted for red in the NDVI calculation because blue light absorption is also correlated with photosynthesis. The low altitude of a small UAV mitigates atmospheric interferences in the blue band. Having all the bands needed for an NDVI produced in a single, affordable camera greatly simplifies processing into an NDVI data layer. BTW, I have no affiliation with MaxMax.com, I just wanted to show the availability of an alternative to the traditional RGB+NIR imagery for vegetation analysis. It becomes a practical alternative when we use low-flying UAVs. Simplicity and efficiency = good for agricultural applications.
Below is a sample of a false color blue NDVI data layer created using a single camera. Blue indicates low NDVI (bare soil in this example); yellow to red indicates higher NDVI (wheat in this example):
Comment by JP on February 10, 2013 at 4:51pm Thanks for the great comment! You are exactly right, the same data can be obtained with a single camera. The only draw back is you don't get a visible (RGB) image with the results. Thanks!
Comment by FlyingMerf on February 10, 2013 at 5:10pm I hope someone will figure out how to make an affordable, light weight, true 4-band camera. It will have soooo many applications!
Comment by JP on February 10, 2013 at 5:16pm me too! i think maybe tetra cam is closest possibility?
Comment by LanMark on February 10, 2013 at 9:05pm @FlyingMerf.. I would love to get into doing this sort of analysis out in my area.. is there any good sites that show how to properly do vegetation stress analysis.. I like the modified camera approach as you probably would have a smaller payload then other methods.
Comment by FlyingMerf on February 11, 2013 at 5:30am
Comment by Rory Paul on February 11, 2013 at 7:37am JP
Have you got any data with regards to the accuracy of the pixel match between the layers? The reason that I ask this is that in my opinion the quantitative value of a two camera method is questionable as long as there is no guarantee that the you are working with data accurately supper imposed.
Comment by JP on February 11, 2013 at 7:43am Hi, the pixels between images are the same size. ~10 cm GSD
Each orthomosaic (VIS and NIRVIS) scene is the same size and GSD. 10772 x 12442 pixels.
The flight was completed with two different cameras and the geo-referenced orthomosaics were generated from the same flight. We provided a shapefile of the area of interest to our processing system and it clips the results to that AOI. This ensures you have the correct sized tifs to complete the BandMath.
Tools such as OTB won't let you process tifs of different sizes for ndvi/evi calculation. Thanks
Comment by Rory Paul on February 11, 2013 at 7:54am The problem in my opinion is that unless you can guarantee that the data from the different channels are aligned down to the pixel and that there are no geometric differences between the layers produced during the othomosiac making processes (angle / rotation) when you perform the NDVI calculation you cannot guarantee that the IR and RED data is been drawn from exactly the same pixel and that could mean the difference between looking at the edge of a leaf or looking at dirt.
Comment by JP on February 11, 2013 at 8:01am Creating orthomosaics of the same GSD and same AOI from the same flight is the best course of action to guarantee that the pixel bandmath matches. Certain tools have these checks built in. Of course, you'll probably experience more noise from lighting conditions/shadows and/or lack of good normalization routine as well.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1295 members
687 members
7 members
24 members
51 members
Powered by
