2.71 Motor Surging Problem
I have run into a problem similar to Peter -
http://diydrones.com/forum/topics/arducopter-2-7-released?x=1&id=705844%3ATopic%3A931552&page=6#comments
wherein the motors under 2.71 surge  regularly just sitting in stable. Under 2.6, my quad runs beautifully, floats like a butterfly. Here is the motors graph (logs, params attached.) from a very nice 2.6 flight-
3690951739?profile=original
But installing 2.71, using 2.71 defaults, makes the motors pulse and they sound just like Peter's sound. It is obvious in the graph-
3690952041?profile=originalI too have done the Marco load old - reset - erase - reconfig, changed Rate P, Stab P  to no avail. Just loading 2.6 back and it flies perfectly, 2.71 and the prob appears. Is anyone else having this prob? Are there any params I am missing?
On the good side, I love the new UBlox! I see a lot more accuracy even in 2.6, but even better getting a fix in 10 seconds rocks!
2.6 with 2.6 param.log
2.71 default param.log
param 2.71 default.param
    Hi John,
    Are you saying the noise is during alt hold or all the time?
    If you are saying alt hold:
    The throttle_rate_P value can pump noise from the climb_rate calculation into the motors. It is higher in 2.7 than 2.6 by default since we have a new filtering mechanism. Use the 2.6 gains and let me know if it goes away. If not, I'll give you a patch that reverts to the 2.6 baro climb rate calculation.
    Thanks!
    Jason
