I am wondering if anyone is flying a platform that achieves 30 minutes flight time in practice, while carrying a small camera.
The Phantom 2 Vision is close, at 20 to 25 minutes from a 5200mAh battery, but I am looking for a platform with more equipment flexibility. My Arducopter 3DR-B and my Hoverthing Flip FPV Pro are nowhere near the duration.
If you are flying a copter which gets 30 minutes or more with a camera, would you please share your setup?
Thank you
Knut
I'm getting 35-40 minute flight time with this build, carrying a 3-axis DYS Gimbal and GoPro Hero 3:
Frame: DJI F550 Top and Bottom Plates / Aeroxcraft X55 extended arms (makes this 650 class)
Controller / Autopilot: Pixhawk with flight modes Loiter / RTL / Drift / Auto / Stabilize / Alt-Hold
ESC: DJI E600 20A Opto
Motors: DJI 3508 / 415kV
Props: DJI E600 12 x 4.2
Motor to motor distance: 12-1/2"
Battery: 6S-16,000 (35min - 40min) 4S2P - 5,000 (10,000 total, 21min), 4S1P - 5,000 (17min) all times mixed flight
Total Weight: 4000gr / 8.75lbs with 16,000mAh batt.
Radio: Futaba T14SG
Video/OSD: MinimOSD on TS832 TX
other: Bluetooth module, strobes, 27" LED Ring, DYS 3-axis gimbal, 12V and 5 BECs, 3 video source switcher
A quick little flight video:
http://youtu.be/Lsgoq-Mm5hM
I get from my 450 quad. 30 minutes hovering with 4s 5000 mah. 12,5 inch props. Nothing attached. Weight is 1500 grams
The only problem is the props almost touch each other. And also give a little inteference to each other. The props are cheap ass slowfly props.
Video Will follow.
I've made an X8 for redundancy that runs 27 min on 20,000mAh. Weighs 5Kg with a Nikon L610 and 2 axis gimbal, video Tx and telemetry
Hovers at about 40%
8 x Multistar 4820 pancakes 690kv, 15x8 APC E props
that's 2 X 6S 10,000 mAH? Which frame are you using on X8
On my coax Octo, I get 17 minutes of real flight time with a 2 axis gimbal & Sony NEX5 camera + FPV:
-Tiger motors 3515-400Kv
-XOAR props 15x5"
-Simonk Hobbyking flashed Blueseries 40A (overspec'd)
-VulcanUAV frame (CF+Al)
-VulcanUAV dampening (vibration isolation) plate
-Home made plywood vibration isolation plate (4 cinestar red silicon rings)
-Kamkop NEX5 Gimbal+Alexmos+3S separate battery 1000mah nanotech HK
-4 VulcanUAV High Landing legs
-2x 6000mah 6S Batteries (Hobbyking nanotech)
-MinimOSD
-433Mhz telemetry
-FPV (hdmi converter cable on NEX5)+ IBCrazy Antenna+Vtx
-Pixhawk (I am not flying an octo with APM)
-Attopilot
-Dual BECs for triple Pixhawk redundant power supply
-FrSky Rx
-External COmpass+GPS
-And...a plastic flower pot as electronics protection.
AUW 6.8 Kg
And this. http://m.youtube.com/watch?v=BDP6EHtCAuQ
I too have been searching for a 25 to 30 min 600+ size multi-rotor. Must be FPV+gimbal and GoPro. I have only found options. There is a build for a 20min + Tarrot 690S:
Tarot FY690S
Friends of mine are working on a quad with 400kv-class motors and 17 inch props, running on 6s, and they are achieving 30 minutes with camera on gimbal, I have been told. I will updated once I learn more.
http://www.rcgroups.com/forums/showthread.php?s=b0b825ff12cd59c32ab...
