Hello all!
I know the BLADE 350QX doesn't belong much in DIY Drones. But I started in quad copters with out and even though i have 2 APM 2.6 quads on the go i still use my 350QX!
I updated to the new firmware and created a quick EEPROM for it using all 4 flight modes:
This is a work in progress
SF - UP Throttle hold (throttle kill)
SF- DOWN Throttle release (you need to have this switch down to start motors)
SA - Master mode switch
SA - UP - Stability Mode
SA - MID - Smart/AP/Agility (Acro) (use SB to select)
SA - DOWN - RTL
SB - Secondary mode switch
SB - UP - Smart Mode
SB - MID - AP mode
SB - DOWN - AGILITY Mode (Acro)
SC - HIGH/MED/LOW rates (MUST BE IN HIGH RATES TO START MOTORS)
Flight modes 1-5 have been set up so when you use the switches it will display on the screen which flight mode you are in. I haven't recorded any wav files for the flight modes yet.
The reason I set up the mode switches the way I did is so i can easly switch to Stability mode or RTL quickly. Switch SA overrides switch SB.
I also had my sliders and pots controlling ELE, AIL, and RUD +25% when in AP mode but i removed that from this EEPE to make it simple. I used them for very fine constant movement when filming. Let me know if anyone wants it.
Let me know what you think of the set-up!
I still don't have the new arming sequence working yet but i will work on that later!
Enjoy!
http://rcsettings.com/index.php/viewdownload/6-multirotors/108-tara...
