while my research during my first custom quad build, i have got these questions about many terms that affects the cost,design and flight time
- What is the affect of motor to motor diameter ?
- What is the affect of maximum propellers length ?
- How to measure quadcopter speed
- How to measure air density ?how it does affect the flight time ?
- Ground speed vs quadcopter speed ?
- how to measure quad altitude ?
- can i get see , altitude on screen using mini OSD ?
- i am using mini OSD, any programming for it is needed ?or it can be used off shelf ?
- is it a must to reprogram the ESCs i.e. flush BLHeli firmware ?
- does a frame has a max payload weight to carry ?
- foam vs metal vs wood frame ? i saw in flitetest.com a section for wooden frames , their is something called anycopter frame which is wood one .
thanks
shaheen
