Hi
I m using apm 2.6 with tarot 680 and samsung nx1000
I made a shutter for camera to A9 everythings works OK.
I made a grid mission takes photos with digicam control, arducopter completes her mission flawlessly..
Now I just get the logs.
but i need to get the time of A9's shutter second, or
there is nothing about digicam control in Flight logs. Should i activate it? or
can i see the IMU of apm when the shutter works?
I cant find it. I will be glad if you answer about it.
Greetings.
ok here is the solution adding camera to logs.
I will share the results after flight.
thank you guys..
Nice work.
Yeah its not activated..
i m on log_bitmask menu
there is
disabled
default
default+IMU <== its selected.
default+motors
nearly all
should i select nearly all?
Interested in this response also, did you process the log file? Possibly when you dump it to a Google earth format the information will carry. I have yet to setup a trigger from the Pixhawk rather using an alternative method of coordinated time, and automating the shutter.
Coordinating this onboard does have its advantages.
