WARNING to TradHeli users:
Do not attempt to fly AC3.3 until you hear otherwise from me. I have not even bench tested it yet, let alone test flown it. There are quite a lot of changes that have gone in that could be crash-o-matic for helicopters.
AC3.3 release for Tradheli is likely to be delayed.
This post will serve as the official release progress thread for TradHeli.
Warning: DO NOT FLY RC6! It has a critical bug that will likely end in a crash.
Warning for RC5:
RATE_YAW_FILT_HZ param will change defaults from 5Hz to 20Hz to be more suitable for helicopters. If you have never changed this parameter from 5 before, then it will automatically update the value to 20 without warning. This much faster filter will probably require reduction in your P and D terms, and the yaw may oscillate badly. Be prepared to retune these. As a safety measure, probably cut them in half for your first take-off.
Warning #2 for RC5:
I accidentally broke the Landing Detector. It will probably never trigger. You should land in Stabilize mode, or be prepared to shut down the motor as soon as it touches the ground in Alt_Hold, Loiter, Auto, etc.
@Fred Goeddert
Leave your e-mail address
My videos are on youtube.com, you can view my column:https://www.youtube.com/channel/UCJZjaDp78PKNFgLfDsm1J5A
I am interested to see a copy of your file. Are you be able to attach it to an e-mail if I give you my address? I have seen your videos with interest.
Having a 500 with APM2.5 and a 700 with Pixhawk - 3.2.1 myself. Just in a process of converting 500 to Pix-hawk.
Fred
It has been sent !
please pay attention to safety.
These parameters are not necessarily suitable for your helicopter, because of mechanical installation and commissioning of each helicopter is different, it is recommended that you should pay attention to all aspects of security!
I tested the day before yesterday for the first time AC3.3rc6 on My T-rex500, basic flight conditions can also, with rc5 was close, but after the automatic landing, did not disarm the master within a certain time, it had not been able to close the signal output ESC, leading after a few seconds, left-leaning body occurs gradually, the main rotor sweep the ground, I was forced to forcibly close the output ESC, which is open only to allow the aircraft to stop stalling switch power output!
The attached log, please ignore the larger Vibration
AC3.3rc6 Heli.rar
Ok, thanks, I'll try to have a look at this. I did a landing in Loiter last night with RC7, and it worked OK.
One issue, I think is that with 3.2, the system would disarm automatically after about 3-4 seconds on the ground. Now it will not disarm until 15 seconds. You have to disarm manually, or just shut the rotor off yourself.
Is this, 3.3rc6 、rc7 must have to disarm manually, or just shut the rotor off yourself.
However, before cutting off the motor signals, like IMU still adjusting posture, so prone to roll and cause the main rotor to scrape the ground
RC6 should be coming out tomorrow, and the land detector should be working now. Or at least it should be better.
20
21
22
23
24
of 29 Next
