I have a quadri copter , in according to istruction for build I assembly the propeller with engine :
2-engine and propeller rotate at CW with appropriate propeller direction
and
2-engine and propeller rotate at CCW with appropriate propeller direction
The engine have a support to connect the engine with the propeller , It's a screw with a Nut. The problem is when the motor rotates in CCW the support has a nut to CW but when the another 2 motors rotate in CW the support of connect propeller has a nut to CW and in many acceleration of engine the nut screw off !!
How resolve this problem?
PS: The engine are turnigy D3530/14
Tighten it better. Or get better prop adaptors. Avoid loctite. You need to remove the props for safety, and to replace broken props.
Many people, including Jason Short use and recommend Great Planes Electrifly Prop Adaptor part GPMQ4962 Motor Shaft Collet (3.175mm, 5mm output shaft) See http://www.electrifly.com/miscproducts/propadapters.html for photos and all the options/sizes.
