Our next Virtual Race will be on June 4th:
https://www.meetup.com/DIYRobocars/events/285787423?utm_medium=referral&utm_campaign=share-btn_savedevents_share_modal&utm_source=link
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
That's exactly what i was looking for originally. In the hopes that you have done this before, i got three questions i hope you could answer
1)In Script.sendRC, when is the value sent when the "sendnow" boolean is false?
2)Can i somehow check the connection between the drone and the GCS? I know that there are failsafe parameters regarding that specific comm with predefine instructions on what to do according to the value set in case the signal is lost for 5 Secs or more, but what if i want to define my own set of instruction on what to do when that comm is lost?
3)Can i inject waypoints via script? I saw an example that imported mission planner utilities i think? In order to do this But i cant find the library anywhere.
Thanks in advance!
To answer the question, yes GCSs are scriptable. Here's how to script Mission Planner with Python:
http://ardupilot.org/planner/docs/using-python-scripts-in-mission-p...
Anyhow, im not at home right now so i'll have to check the links later, this seems promising, Asim. I did a quick search on Ardu Pilot but im not 100% clear with what it exactly is, can you elaborate real quick on it? It's not a GCS that much i figured.
I also have one more question but its regarding Ground control stations as i'm rather new to this. I know they monitor the position of the drone at a all times, and allow you to set the flight mode and even send "Messages" to the drone. Are they in any way programmable? automizing the GCS via scripting might be more efficient. For example once it reaches x way point position, ill tell the GCS to switch from "AUTO" to flight mode "HOLD", since this is similar to what im trying to do but i'm doing it within the PIXHAWK.
I've read about MAVLINK protocol and it may be a better option than the PIXHAWK's uOrb communication API, but i just havn't seen any proper documentation regarding the code side of it and im sort of lost in properly understading it.
Thanks! And it's not a thesis per say but an essential part of a research collaboration with MIT lincoln labs and other engineers.
Thanks for commenting and sorry for the late reply. Im not sure i quite understood the question so First thing first, this is strictly software. Two apps are going to be uploaded to the FC(PIXHAWK). Im writing an app(via uORB messaging in c++) that monitors the current location of the drone so that when its location matches that of the waypoint's, the drone stops and executes the other App, but for this i need to access the waypoints coordinates that were uploaded to the pixhawk, is this possible to do via code?
