Add sensors to my quadrotor
Hello everyone,
I want to add a sensor that measures the wind speed to my quadrotor. I need also a temperature sensor with high accuracy. Does anyone know anything about a company that sells these senors?
Thank you.
  • That's called an airspeed sensor and 3DR sells them. Measuring wind speed on a quadrotor though is pretty complicated; depending where you place it you get incorrect air pressure readings or incorrect references.
    The APM has a temp sensor on board in the form of the MS5611, which is a barometer with temp output.
