Thanks very much. Because I read the wiki on the power set up and I know it is ok to use a SBEC when the jumper is removed but it recommends 5v and I was unsure if using the maximum of 5.5v was ok. So I should also disconnect it when I plug it into my USB the same as I should disconnect the battery from the power module too?
Still have not powered up my APM due to being unsure of connection/configuration for servo's/ receiver etc. If I have my battery plugged in one end of the standard APM power cable the SBEC connected via the main wires to the other end, the 5.5v cable from the SBEC to the side pins closest to JP1 jumper(removed), then my servo's connect with all three wires to the side length-side, my Futaba Rx then connects to the other end opposite the JP1 and 5.5v SBEC pins. Would I connect it to the SBUS port on my Futaba or just the standard 1,2,3,4....channels with only one positive connector the rest just ground and signal wires? I should add that two servo's are connected as one with a Y servo wire connector for the V-tail.
