No matter what I do, I cannot get aileron and elevator swapped so they are correct. I am running a Hitec Aurora 9 receiver. I have tried my transmitter in Acro, Heli Swash 0, swapping channels, swapping joystick control modes, swapping cables will fix it, but the copter doesn't fly right because the arducopter controller is confused I assume.  I'm sick of going through props.
Running APM 1.0.52 with 2.0.38 beta code, quad set to x, radio calibrated, one mode switch in stabilize, simple and alt hold. I am trying to take off in stabilize.
I have tried using Ardupirates software and Aeroquad with no luck. I purchased my Arducopter from udrones.
Does anyone have any ideas?
Totally willing to post anything needed to get this thing off the ground so I can start tuning it!
    I didn't realise copters were fitted with ailerons, rudder or elevator :-P
    Do the radio test in the CLI. Move sticks to the lower right (pitch back, roll right) You should see approx 4500 for both values.
    Roll right should happen on Ch 1.
    Then test your motors are hooked up in the correct order based on the wiki.
    Your subject line says ailerons and rudder are swapped, but the post says ailerons and elevator. Which is it?
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
