APM won't connect via radios
Howdy,
So, I just got the RCTimer radio modules, and I'm having a bit of trouble. They worked fine at first. I had the APM 2.5 connected to Mission Planner using the default settings, and telemetry seemed to work just fine. I did a range check, and got maybe 1000 meters range through trees and houses etc... So, I tried to lower the baud rate and airspeed rate to squeeze some more range out. This seems to have caused two problems; Now the APM won't talk to Mission Planner through the radios (USB works fine). It seems like the radios are connected, as both have a solid green light, and I can see them both in the configuration utility. Also, I can't seem to change the settings on the 'air' module anymore, and it seems to be stuck working at 16k airspeed. How do I get the APM to connect again? Is there a baud rate I have to set in the APM somewhere? I'm also curious how I'm supposed to change the airspeed again. Any help would be much appreciated.
-Nate
  • Yup, still stuck on this. I'm gonna have to get an FTDI serial converter to program the air module, then I might be able to do some real troubleshooting.
  • Ok, disregard on the not being able to connect to the APM... Turns out there's a parameter to adjust the telemetry rate, go figure. I guess I should probably get an FTDI adapter and use that to change the settings on the air module anyway.
    Now, about halfway through connecting with Mavlink via the radios, I get a message with the following details.
    3692743031?profile=original
